SAVE/EXPORT problem
SAVE/EXPORT problem
Postby randomroutine » Thu May 20, 2010 8:13 am
hi.
first of all, congratulations for this project!
i just would be happy to find out why i cannot export...
i read through some topics related to this, and doubleclicking the save button doesnt work for me. folders are writable, im admin too.
i tried to export as "testexport"
krisztian
Time to apply colors 0.000999927520752
loading wavefront data/3dobjs/empty.obj in 0.000000 sec
time to build mesh: 0.0
loading wavefront data/3dobjs/slider_background.obj in 0.000000 sec
loading data/themes/default/images/slider_generic.png
loading wavefront data/3dobjs/slider_cursor.obj in 0.001000 sec
loading data/themes/default/images/slider.png
loading wavefront data/3dobjs/slider_cursor.obj in 0.000000 sec
time to build mesh: 0.000999927520752
loading wavefront data/3dobjs/button_standard_big.obj in 0.000000 sec
loading data/themes/default/images/button_about.png
loading data/themes/default/images/button_exit.png
loading data/themes/default/images/button_modelling_on.png
('setFocus', <gui3d.Slider instance at 0x06B6CB48>)
loading data/themes/default/images/slider_focused.png
loading data/themes/default/images/macro_on.png
loading data/themes/default/images/upperbar.png
loading data/themes/default/images/lowerbar.png
loading data/themes/default/images/lowerbar2.png
loading data/textures/texture.tif
loading data/themes/default/images/group_main.png
loading data/themes/default/images/group_actions.png
loading data/fonts/arial_0.png
loading data/themes/default/images/button_undo.png
loading data/themes/default/images/button_redo.png
loading data/themes/default/images/button_reset.png
loading data/hairs/default.png
loading data/themes/default/images/button_background_toggle.png
loading data/themes/default/images/details.png
loading data/themes/default/images/group_details_gender.png
loading data/themes/default/images/group_details_face.png
loading data/themes/default/images/group_details_pelvis.png
loading data/themes/default/images/group_details_head.png
loading data/themes/default/images/group_details_modifiers.png
loading data/themes/default/images/button_translation_on.png
loading data/themes/default/images/button_scale.png
loading data/themes/default/images/button_symmright.png
loading data/themes/default/images/button_symmleft.png
loading data/themes/default/images/button_symmetry.png
loading data/themes/default/images/button_unselected.png
loading data/themes/default/images/micro.png
loading data/themes/default/images/button_translation.png
loading data/themes/default/images/button_files.png
loading data/themes/default/images/button_save_file.png
loading data/themes/default/images/texedit_off.png
loading data/themes/default/images/button_confirm.png
loading data/themes/default/images/button_load_file.png
loading data/themes/default/images/button_export_file.png
loading data/themes/default/images/group_export_option.png
loading data/themes/default/images/button_export_obj_on.png
loading data/themes/default/images/button_export_mhx.png
loading data/themes/default/images/button_export_collada.png
loading data/themes/default/images/button_export_bvh_on.png
loading data/themes/default/images/button_export_group_on.png
loading data/themes/default/images/hair_export_mesh_on.png
loading data/themes/default/images/hair_export_curves_off.png
loading data/themes/default/images/button_render.png
loading data/themes/default/images/button_advance.png
loading data/themes/default/images/makehair.png
loading data/themes/default/images/button_library.png
loading data/themes/default/images/button_hair.png
loading data/themes/default/images/button_background.png
loading data/themes/default/images/button_aqsis.png
loading data/themes/default/images/button_hair_det.png
loading data/themes/default/images/group_hair_tool.png
loading data/themes/default/images/slider_red.png
loading data/themes/default/images/slider_green.png
loading data/themes/default/images/slider_blue.png
loading data/themes/default/images/button_measure.png
Regeneration done in0.282999992371
Buffer time 0.007000207901
Buffer time 0.00600004196167
Buffer time 0.117000102997
Buffer time 0.21599984169
('setFocus', <gui3d.ToggleButton instance at 0x06CE89B8>)
loading data/themes/default/images/macro.png
loading data/themes/default/images/button_modelling.png
('setFocus', <guirender.RenderingCategory instance at 0x06CE87D8>)
loading data/themes/default/images/button_render_on.png
('setFocus', <gui3d.ToggleButton instance at 0x06C96F08>)
loading data/themes/default/images/button_files_on.png
loading data/themes/default/images/button_save_file_on.png
('setFocus', <gui3d.FileEntryView instance at 0x06C9A0A8>)
('setFocus', <gui3d.TextEdit instance at 0x06C9A300>)
loading data/themes/default/images/texedit_on.png
('setFocus', <gui3d.ToggleButton instance at 0x06CD71C0>)
loading data/themes/default/images/button_export_file_on.png
('setFocus', <gui3d.FileEntryView instance at 0x06CDA878>)
('setFocus', <gui3d.TextEdit instance at 0x06CDAAA8>)
File "./mh_core\module3d.py", line 1411, in mouseButtonUp
self.application.mouseUp(button, x, y)
File "./mh_core\gui3d.py", line 476, in mouseUp
self.mouseDownObject.callEvent('onClicked', event)
File "./mh_core\events3d.py", line 93, in callEvent
getattr(self, eventType)(event)
File "./mh_core\gui3d.py", line 925, in onClicked
self.onFileSelected(self.edit.getText())
File "./mh_plugins\guifiles.py", line 196, in onFileSelected
mh2obj.exportObj(self.app.scene3d.selectedHuman.meshData, os.path.join(expor
tPath, filename + ".obj"), 'data/3dobjs/base.obj', self.exportGroups.selected)
File "./pythonmodules\ntpath.py", line 101, in join
path += b
UnicodeDecodeError: 'ascii' codec can't decode byte 0xe1 in position 10: ordinal
not in range(128)
path += b
not in range(128)
path += b
not in range(128)
randomroutine
Re: SAVE/EXPORT problem
Postby joepal » Thu May 20, 2010 8:23 am
Do you have any non-ascii characters in the path name to your home directory? Seems to me something is happening when it tries to decode the string containing the path name.
Postby mflerackers » Thu May 20, 2010 8:59 am
Yes, we should move to utf8 coding for our files to avoid this. It might be adding an extra line at the top like # -*- coding: utf-8 -*- though I'm not sure.
MakeHuman project Developer
mflerackers
Postby randomroutine » Thu May 20, 2010 9:05 am
yes i have a hungarian long a. shit
randomroutine
