MakeHuman Not Starting
Postby Transentient » Sat Jan 23, 2021 6:03 pm
Having had a PC rebuild I downloaded and re-installed MakeHuman, using the lastest version 1.2.0. Installation ran with out problem, however when I run MakeHuman nothing happens.
My PC is Windows 10 Pro Version 20H2
Graphics Card is an Nvidia GeForce GTX 1060 - with latest driver up date
I have also attached the MakeHuman log files, as recommended although I cannot upload python_out as it is an empty file
To be sure, I un-installed, re-downloaded and re-installed, with the same result.
Any clues? I have used MakeHuman, in different versions for some time without issue.
Thanks in advance. Stay safe and well out there
makehuman.log
(119 KiB) Downloaded 1655 times
makehuman-debug.txt
(2 KiB) Downloaded 1652 times
python_err.txt
(837 Bytes) Downloaded 1663 times
Transentient
Re: MakeHuman Not Starting
Postby Aranuvir » Sat Jan 23, 2021 8:10 pm
Go to the makehuman/v1py3 folder and delete settings.ini (maybe all other ini files, too). If this does not fix your issue make sure to avoid any non-ASCII allover MakeHuman, or force Windows to use utf-8. Perhaps this link is helpful, too: https://docs.microsoft.com/en-us/window ... -code-page (Can't/won't do any testing, because generally I'm not a Windows user...)
Postby Transentient » Tue Jan 26, 2021 7:04 pm
Thanks Aranuvir
Deleting the ini files seems to have done the trick. Makehuman now starts
Transentient
Postby vineetsinghldh » Thu Dec 07, 2023 11:13 am
Can't find that folder
vineetsinghldh
