makehuman.py - run from terminal
Postby Aussie_xt » Tue Feb 25, 2020 1:54 pm
i found few bugs while trying to run makehuman in makehuman.py and can't run from terminal
if argOptions.get('license', False):
print "\n" + getCopyrightMessage() + "\n" should be print ("\n" + getCopyrightMessage() + "\n") ??
sys.exit(0)
and similar
def main():
print getCopyrightMessage(short=True) + "\n" should be print (getCopyrightMessage(short=True) + "\n") ??
Thanks.
Aussie_xt
Re: makehuman.py - run from terminal
Postby joepal » Wed Feb 26, 2020 6:31 am
Which version of makehuman is this? It seems that you are trying to run the old python 2 code with a python 3 interpreter, which will not work.
The current makehuman code is here: https://github.com/makehumancommunity/makehuman
