Compiling makehuman on linux
Postby Setlec » Mon Aug 17, 2009 1:17 pm
Hello there i've been trying to compile makehuman on linux (mandriva) but i'm having issues.
./compile_src.sh
./src/glmodule.c: In function ‘OnInit’:
./src/glmodule.c:926: error: ‘glActiveTexture’ undeclared (first use in this function)
./src/glmodule.c:926: error: (Each undeclared identifier is reported only once
./src/glmodule.c:926: error: for each function it appears in.)
./src/glmodule.c: In function ‘mhDrawMeshes’:
./src/glmodule.c:1186: warning: implicit declaration of function ‘glActiveTexture’
here is the Scons compile process
scons build=release
scons: Reading SConscript files ...
Checking for C library python2.6... yes
Checking for C library X11... yes
Checking for C library SDL... yes
scons: done reading SConscript files.
scons: Building targets ...
gcc -o src/core.o -c -O2 -Iinclude -I/usr/include/python2.6 -I/usr/include/GL -I/usr/include/SDL src/core.c
gcc -o src/glmodule.o -c -O2 -Iinclude -I/usr/include/python2.6 -I/usr/include/GL -I/usr/include/SDL src/glmodule.c
src/glmodule.c: In function 'OnInit':
src/glmodule.c:926: error: 'glActiveTexture' undeclared (first use in this function)
scons: *** [src/glmodule.o] Error 1
scons: building terminated because of errors.
are you guys haing the same problem?
Setlec
Re: Compiling makehuman on linux
Postby joepal » Mon Aug 17, 2009 1:26 pm
The nightly build completed without errors tonight, so unless someone messed up the subversion repository after 06:00 GMT something else must be wrong.
Can't figure out what from the output though.
Postby mflerackers » Mon Aug 17, 2009 1:34 pm
On Ubuntu linux 9.04 it compiled, but it declares glActiveTexture in gl.h. Maybe Mandriva has another version of mesa? In that case we need a better test instead of
#ifdef __WIN32__
glActiveTexture = (PFNGLACTIVETEXTUREPROC)SDL_GL_GetProcAddress("glActiveTexture");
#endif
on lines 82 and 914 in glmodule.c.
MakeHuman project Developer
mflerackers
Postby Setlec » Mon Aug 17, 2009 2:34 pm
mesa? well i've got nvidia driver installed version 180.60. Maybe updating the driver could fix it? in any case i'll install mesa package.
Edit: i've checked mesa and i've got all *mesa* devel installed nothing changed...
Setlec
Postby mflerackers » Mon Aug 17, 2009 2:52 pm
did you try removing the two #ifdef's I mentioned?
mflerackers
Postby Setlec » Mon Aug 17, 2009 3:04 pm
just did! got a successful build, thanks [EDIT] but that's my console log while running the software
setlec@localhost:~/workspace/makehuman-read-only/makehuman$ ./makehuman
POV-Ray Export Parameter File
Version 1.0.0
loading wavefront data/3dobjs/splash.obj in 0.000121 sec
time to build mesh:  9.79900360107e-05
WARNING: Unable to open color file data/3dobjs/splash.obj.colors
loading data/themes/default/images/splash.png
Could not load data/themes/default/images/splash.png, SDL_image not found
'NoneType' object has no attribute 'cameraMode'
'NoneType' object has no attribute 'visibility'
'NoneType' object has no attribute 'shadeless'
loading wavefront data/3dobjs/progressbar_background.obj in 0.000088 sec
time to build mesh:  8.89301300049e-05
WARNING: Unable to open color file data/3dobjs/progressbar_background.obj.colors
loading data/themes/default/images/progressbar_background.png
Could not load data/themes/default/images/progressbar_background.png, SDL_image not found
loading wavefront data/3dobjs/progressbar.obj in 0.000114 sec
time to build mesh:  8.39233398438e-05
WARNING: Unable to open color file data/3dobjs/progressbar.obj.colors
loading data/themes/default/images/progressbar.png
Could not load data/themes/default/images/progressbar.png, SDL_image not found
'NoneType' object has no attribute 'setScale'
Regeneration done in0.00074291229248
/bin/sh: aqsl: command not found
/bin/sh: shaderdl: command not found
/bin/sh: sdrc: command not found
loading wavefront data/3dobjs/upperbar.obj in 0.000161 sec
time to build mesh:  0.000111103057861
WARNING: Unable to open color file data/3dobjs/upperbar.obj.colors
loading data/themes/default/images/upperbar.png
Could not load data/themes/default/images/upperbar.png, SDL_image not found
loading wavefront data/3dobjs/backgroundbox.obj in 0.000090 sec
Time to apply colors  7.58171081543e-05
loading wavefront data/3dobjs/lowerbar.obj in 0.000120 sec
time to build mesh:  9.10758972168e-05
WARNING: Unable to open color file data/3dobjs/lowerbar.obj.colors
loading data/themes/default/images/lowerbar.png
Could not load data/themes/default/images/lowerbar.png, SDL_image not found
loading wavefront data/3dobjs/base.obj in 0.541051 sec
time to build mesh:  0.844375133514
Warning: Color data does not match number of vertices ( 22824 vs 22872)
'NoneType' object has no attribute 'shader'
  File "<string>", line 1, in <module>
  File "main.py", line 283, in <module>
    application = MHApplication()
  File "main.py", line 125, in __init__
    self.scene3d.selectedHuman = human.Human(self.scene3d, "data/3dobjs/base.obj")
  File "./mh_plugins/human.py", line 42, in __init__
    self.mesh.setShaderParameter("gradientMap", mh.loadTexture("data/textures/color_temperature.png", 0))
RuntimeError: Could not load data/textures/color_temperature.png, SDL_image not found
Could not run main Python script
^Z
[1]+  Stopped                 ./makehuman
Setlec
Postby mflerackers » Mon Aug 17, 2009 3:11 pm
do you have sdl image installed?
mflerackers
Postby Setlec » Mon Aug 17, 2009 9:40 pm
no i didn't have it installed but i'm instaling right now! thanks guys for your help 'til now!
Setlec
