(Urgent) Blendshapes not exporting with MPFB v2.0 Character
Postby ermelious » Sun Sep 01, 2024 5:27 am
I've followed the official makehuman youtube tutorial to "Bake Blendshapes" as well. Unity still does not detect any blendshapes in the SkinnedMeshRenderer.
Please advice, Thanks.
Tutorial I've followed:
https://youtu.be/YypDcUpON8A?si=t23arspfb3CQ2BmK
ermelious
Re: (Urgent) Blendshapes not exporting with MPFB v2.0 Charac
Postby joepal » Sun Sep 01, 2024 9:40 am
This is theoretical as I don't have a windows machine available atm. But: seemingly the default in the blender fbx export is to apply all modifiers. This would then (again theoretically) also apply all shape keys.
Maybe you can test disabling the apply modifiers checkbox? It might work, but no promise.
Postby ermelious » Sun Sep 01, 2024 10:52 am
joepal wrote:This is theoretical as I don't have a windows machine available atm. But: seemingly the default in the blender fbx export is to apply all modifiers. This would then (again theoretically) also apply all shape keys.
That solved the issue and worked like a charm! Thank you. The blendshapes are now showing in Unity in the SkinnedMeshRenderer.
ermelious
Postby ermelious » Mon Sep 02, 2024 6:41 am
Actually hold up, I did not monitor the changes clearly. While blendshapes shows up, the model is now screwed up as seen here:
Additionally I'm having an issue where if I use the detailed/default rig with toes, when I import to mixamo, the fingers appear to be animated wrongly like some sort of alien. Any advice on this? I'd like to the default rig with toes instead of the one for GameEngine because the GameEngine one does not have the face bones.
ermelious
Postby joepal » Mon Sep 02, 2024 3:23 pm
I don't see any obvious way through which you can only apply some of the stuff in the FBX import.
My best suggestion is to not have any modifiers on the character. For the mask modifier hiding the helper mesh you can apply that by going to operations -> basemesh -> delete helpers. You'll have to experiment a bit though, it's possible this might have a consequence for the blend shapes.
The mixamo import does not work particularly well with the default skeleton. Thus the specific mixamo rig. There is no mixamo version with facial bones as of yet, only a feature request in the issue list.
Postby Zokage269s » Sun Sep 08, 2024 10:35 pm
joepal wrote:I don't see any obvious way through which you can only apply some of the stuff in the FBX import.
This works perfectly
Zokage269s
Postby GameDevHammad » Tue Mar 11, 2025 12:12 pm
I am facing the same issue, I have exported the character without applying modifiers to it, and the blendshapes are not visible in Unity Editor, but the model is messed up the same way and the blendshapes are also not working. Has anyone found the solution to it?
GameDevHammad
Return to Game development
