MH into Godot tutorial
Re: MH into Godot tutorial
Postby tomcat » Sun Jun 19, 2022 9:13 am
I have made some cosmetic changes and very minor corrections. If there are no critical comments, I will post this tutorial on the Godot site next week.
Regarding the posting of this tutorial on the MH site. This is certainly a possibility. But I suppose that the first part will not be interesting for those who already work with MH — it's designed for those who have never dealt with MH before and gives only a basic understanding of the program. The second part will contain the Blender import itself and some non-obvious stuff.
I liked Patreon for its fast and quality support.
— Are birds being milked there?
— In Russia everyone is milked. Here even zucchinis lay caviar…
Postby tomcat » Wed Jun 22, 2022 3:49 pm
Creating a character for games in Godot using MakeHuman
Volume 2
Importing into Blender and assigning animations. Importing into Godot
Need two addons for Blender:
Step 1
Import
The import panel can be called in 2 ways:
  • File –> Import –> MakeHuman (.mhx2)
  • N-панель –> Import MHX2
result is identical:
If you need facial animation, you can:
  • to enable the "Face Shapes" option for emotions via shape keys;
  • if you choose a rig with face bones, then the emotions can be realised by poses.
In Rigging turn on Add Rig and choose Rig Type [Exported].
The rig assigned to the MH will be imported.
[Import MHX2]
Remove all the masks:
If the clothes will be the only one, it's better to leave masks.
Step 2
Assignment of animation
*A little note. For the game, the animation must be played without moving the character. Moving the character is done in the game engine by moving the object itself. As the animation in the example contains movement, you need to get rid of it (or take the animation already prepared). You can choose any convenient way for the character to stay in place. In my opinion, the easiest is to tie the Hips(root) bone to the position at rest. The way is not the best, but simple and fast. To do this, I make a copy of the skeleton at rest position. This is only necessary for binding.
To assign the animation use Retarget BVH plugin finalized by punkduck (for which he is very thankful).
[Load And Retarget] allows you to load animation and immediately apply to the character.
Select animation (02_01.bvh) and load it.
*Now bind the Hips animation bone to the rest pose bone for the character to walk in place.
Add the running animation (02_03.bvh).
Now the file is ready to be exported to Godot.
The documentation for the engine recommends that you triangulate the models.
But Blender does not allow you to triangulate an object that contains shape keys:
Modifier cannot be applied to a mesh with shape keys
Step 3
Godot. Import
The Blender Importer Addon for Godot allows you to open Blender files as Godot scenes.
This feature is built into Godot 4, but it doesn't work correctly there.
Just save the .blend file in your project folder and it will be automatically imported into the engine.
In an open scene, you can remove the resting pose skeleton you don't need anymore and separate clothes by scene for easy switching:
Video
Face morphs will be transferred, but you must remember to set the same Shapes settings for different body parts.
The main part of the tutorial is finished.
Translated with http://www.DeepL.com/Translator (free version)
Postby tomcat » Thu Jun 30, 2022 8:29 pm
Some suggestions that arose during the creation of the tutorial
  • Make an option in .mhx2 to save body parts and clothes separately, so they would be automatically put into Blender collections (for example, body parts into "body parts" collection, and clothes into "clothes" collection, maybe even by categories: "sports", "casual"…).
  • Support importing collections from Blender, so that Blender collections open as nodes in Godot.
Postby tomcat » Sat Jul 02, 2022 6:33 pm
Volume 3
  1. Change of hair (eyebrows, eyelashes, teeth).
  2. Body Shapes (Shape Keys).
Part 1
Step 1
Changing body parts is somewhat different from choosing clothes. Since you can't have a character with several hairstyles (unlike clothes), you have to work with each hairstyle individually.
It is assumed that there are already:
  • the original MakeHuman model, which needs to be modified;
  • a Blender file derived from this model.
Load the model for which you want to change the hairstyle. Choose the hairstyle you want:
bob02
author
Joel Palmius
Jonas Hauquier
If you want, you can add eyebrows, eyelashes, teeth to transfer. It is better to remove unnecessary things.
The model is exported in .mhx2 format ("Scale units" in meters).
Step 2
Blender
Opens the previously saved file with the original model.
  1. The file with the new hairstyle is imported into it.
  2. The hairstyle is transferred to the collection to the original model and linked (with a Shift).
  3. The armature from the original model is assigned.
  4. The entire new collection should be deleted.
  5. The file is saved to the Godot project folder.
Step 3
Godot
The Blender file imported into Godot can be saved as a new scene. If the previous file was already saved as a scene, the hair can be transferred to it as a node.
Postby tomcat » Sun Jul 24, 2022 6:41 pm
Final part of the tutorial.
Volume 3
Part 2
Shape Keys
Assignment of shape keys
Step 1
MakeHuman
Load the model into which you want to add the shape key. The model should have clothes, to which a key will be applied to the form. Apply the modifier:
The operation must be repeated for each key.
The model is exported in .mhx2 format (units in meters).
Step 2
Blender
Triangulation
The engine documentation recommends triangulating the models.
But Blender does not allow you to triangulate an object that contains shape keys.
If the model does not contain shape keys, then that model can be triangulated before they are assigned.
Choice of modifiers for shape keys
You may only assign modifiers that do not change the size of the model skeleton! If the modifier changes the dimensionality of the skeleton (e.g. arm/leg length, shoulder width etc.), the result of the animation will be unpredictable.
  1. The modified model is imported into the file with the original model.
  2. The part (body) of the modified model is selected first.
  3. Then the same part of the original model is selected (with CTRL).
  4. Assign a shape key (Object Data Properties –> Shape Keys –> Join as shapes)
  5. The procedure is repeated with the clothing elements.
  6. The entire new collection should be deleted.
  7. The file is saved in the Godot project folder.
Step 3
Godot
The Blender file imported into Godot is saved as a new scene.
There is a bug: if "Bland Shape" is set to 1, artifacts appear:
It is desirable to set the value to less than 1.0:
A huge grateful thanks to those who have helped and supported me:
Postby tomcat » Sat Jul 30, 2022 9:11 am
Some remarks about working with newer versions of the software:
  • In Blender 3, the Retarget BVH plugin does not work yet.
  • Godot 4 does not import .blend files correctly. It is recommended to import via glTF.
Postby tomcat » Mon Aug 15, 2022 5:54 pm
Volume 4
Adding animation
  • Blender file with animation;
  • A scene in Godot derived from this file.
Step 1
Blender
Opens a previously saved file with the original model and animations.
  1. A new animation is imported.
  2. The file is saved in the Godot project folder.
Note. In this example, the jump animation is applied in place. In general, it is desirable to move the model in the game engine, as a node, then it will be possible to change the height of the jump. But in this case, I will show a fixed jump. To do this, leave the constraint of the bone fixed on the X-axis only. This change will affect the existing animations, but they are already in the scene file in Godot.
Step 2
Godot
  1. From the new file imported into Godot, only a new animation is needed:
  2. It can be copied or saved for future use:
  3. Open AnimationPlayer in an existing scene and load the new animation file there by copying or exporting:
That's it, the animation is added to the scene file.
Return to Game development
