Misc Blender Issues
Misc Blender Issues
Postby Ambaryerno » Sat Apr 04, 2020 4:05 am
Hello, I'm new to the application, but have been figuring out the app and getting a decent feel for the basics. However I'm now playing around with the Blender integration for this project, and am running into a number of problems I didn't see anything pertaining to this in the FAQ or release notes, and a general forum search hasn't led me to any specifics for my issues, so I apologize if this has all been covered elsewhere, but sometimes it's just easier to get it all in one place.
For reference I'm running the 1.2.X Alpha, with Blender 2.81.
The first problem I ran into is that I can't activate the MakeClothes plugin. It keeps telling me I need to upgrade to 2.8x. Well, clearly I'm ON 2.8x already, but I can't get around it.
The second is occurring during import. I was able to successfully import my character using the MakeHuman plugin, and MOST of the information on the model comes over. I've got the skin, targets, clothes, hair, etc. However what's NOT getting imported is the Topology. As a test, I ran an export in OBJ format instead, and in that case the topology is being applied during the export. Is export/import of topology just not implemented yet?
I'm also unable to import directly from the file using the MHX2 runtime. I get this error:
Finally, I'm getting some bizarre model corruption when I use the Sync With MH command:
Ambaryerno
Re: Misc Blender Issues
Postby punkduck » Sun Apr 05, 2020 6:38 pm
Sorry atm I can only speak for the mhx2 importer/exporter because I was also involved a little bit. That error looks like the old code, which is only working with Blender 2.7x.
Blender internally changed a lot, meanwhile we are maintaining an own version. I just tested it with 2.82a ... it works.
Remove old import_runtime_mhx2 directory and put new one to the same place (use download).
This is the current version:
https://github.com/makehumancommunity/mhx2-makehuman-exchange
Postby Ambaryerno » Mon Apr 06, 2020 10:58 pm
Ok, that fixed the runtime error in the MHX2 importer. It also partly fixes the problem with the correct Topology not importing. If I use the exported MHX2 file and import it independently, it now loads the export, uses the correct topology, AND properly places the feet on the origin (well, mostly. The origin sets slightly inside the foot rather than at the very bottom. But still, MUCH better than it was).
Using Import from the community plugin is still an issue, but this works. The Sync option on the Community plugin is also still broken.
Incidentally for anyone else who may be able to help, this is the error I get when I use the Community Plugin to import. The model still loads, but as I noted in the OP it doesn't include the assigned Topology, and it also places the origin at Center of Mass rather than the feet.
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\operators\bodyimport.py", line 14, in execute
    ImportBodyBinary()
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 92, in __init__
    FetchServerData('getBodyMeshInfo', self.gotBodyInfo)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\fetch_server_data.py", line 8, in __init__
    self.executeJsonCall(expectBinaryResponse=expectBinary, params=params)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\sync_ops.py", line 18, in executeJsonCall
    self.callback(json_obj)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\fetch_server_data.py", line 14, in callback
    self.readyFunction(json_obj.data)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 134, in gotBodyInfo
    FetchServerData('getBodyVerticesBinary',self.gotVerticesData,True)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\fetch_server_data.py", line 12, in callback
    self.readyFunction(json_obj)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 158, in gotVerticesData
    FetchServerData('getBodyFacesBinary',self.gotFacesData,True)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 176, in gotFacesData
    FetchServerData('getBodyTextureCoordsBinary', self.gotTextureCoords, True)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 190, in gotTextureCoords
    FetchServerData('getBodyFaceUVMappingsBinary', self.gotFaceUVMappings, True)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 226, in gotFaceUVMappings
    self.afterMeshData()
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 372, in afterMeshData
    FetchServerData('getBodyMaterialInfo',self.gotBodyMaterialInfo)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 391, in gotBodyMaterialInfo
    FetchServerData('getSkeleton', self.gotSkeleton)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 469, in gotSkeleton
    FetchServerData('getProxiesInfo', self.gotProxiesInfo)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 475, in gotProxiesInfo
    self.importNextProxy()
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 483, in importNextProxy
    ImportProxyBinary(self.obj, self.name, self.proxiesInfo[self.nextProxyToImport], self.proxyLoaded, self.collection)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 106, in __init__
    FetchServerData('getProxyVerticesBinary', self.gotVerticesData, expectBinary=True, params={ "uuid": self.proxyInfo["uuid"] })
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 147, in gotVerticesData
    FetchServerData('getProxyFacesBinary',self.gotFacesData, expectBinary=True, params={ "uuid": self.proxyInfo["uuid"] })
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 179, in gotFacesData
    FetchServerData('getProxyTextureCoordsBinary', self.gotTextureCoords, expectBinary=True, params={ "uuid": self.proxyInfo["uuid"] })
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 198, in gotTextureCoords
    FetchServerData('getProxyFaceUVMappingsBinary', self.gotFaceUVMappings, expectBinary=True, params={ "uuid": self.proxyInfo["uuid"] })
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 232, in gotFaceUVMappings
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 318, in afterMeshData
    FetchServerData('getProxyMaterialInfo', self.gotProxyMaterialInfo, expectBinary=False, params={ "uuid": self.proxyInfo["uuid"] })
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 338, in gotProxyMaterialInfo
    self.onFinished(self)
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_body_binary.py", line 518, in proxyLoaded
  File "C:\Users\David\AppData\Roaming\Blender Foundation\Blender\2.81\scripts\addons\MH_Community\mh_sync\import_proxy_binary.py", line 121, in gotVerticesData
    assert(iMax == int(self.proxyInfo["numVertices"]))
AssertionError
Ambaryerno
Return to Blender
