Can't seem to get MakeHuman Plugin for Blender (2.8) running
Postby SaltyCowdawg » Mon Nov 25, 2019 3:17 pm
First: a rant. I hate Python with an all burning passion because of its extreme symptoms of versionitis. I right now have both Python 2.8 and Python 3.8 on my system and I've done a symlink so /usr/bin/python points to the 3.x. Thiis all in my attempt to get the plugin working.
end of rant
I don't seem to be able to copy/paste the errors Blender is spewing when I try to activate the MakeHuman for blender plugin but the crux of it seems to be in its inability to load "multiarray" from numpy.core. So I chased around the internet checking out other folks who have run into this symptom and haven't gotten anywhere.
I'm running Ubuntu 18.04 on my desktop.
Thoughts anybody?
Re: Can't seem to get MakeHuman Plugin for Blender (2.8) run
Postby joepal » Mon Nov 25, 2019 4:09 pm
In case you are trying to run Ubuntu's deb packaged blender: don't. You are better off downloading a zip file from blender and run that.
If not, try starting blender from a terminal prompt to catch the error output.
Postby SaltyCowdawg » Mon Nov 25, 2019 5:44 pm
Messages from where /usr/bin/python is lined to Python 3.x
Read prefs: /home/peter/.config/blender/2.82/config/userpref.blend
Loading MHX2 importer-runtime v 0.30
build loaded
MHX2 armature loaded
MHX2 successfully (re)loaded
Rock Generator: Numpy not found.  Using Python's random.
Rock generator settings file found:
/usr/share/blender/2.82/scripts/addons_contrib/add_mesh_rocks/add_mesh_rocks.xml
Loading MH community plug-in v 0.6.2
Loading sync plug-in
  File "/usr/lib/python3/dist-packages/numpy/core/__init__.py", line 16, in <module>
    from . import multiarray
ImportError: cannot import name 'multiarray' from 'numpy.core' (/usr/lib/python3/dist-packages/numpy/core/__init__.py)
During handling of the above exception, another exception occurred:
  File "/usr/share/blender/2.82/scripts/modules/addon_utils.py", line 351, in enable
    mod = __import__(module_name)
  File "/home/peter/.config/blender/2.82/scripts/addons/MH_Community/__init__.py", line 22, in <module>
    from . import mh_sync # directory
  File "/home/peter/.config/blender/2.82/scripts/addons/MH_Community/mh_sync/__init__.py", line 21, in <module>
    from . import import_body_binary
  File "/home/peter/.config/blender/2.82/scripts/addons/MH_Community/mh_sync/import_body_binary.py", line 15, in <module>
    import numpy as np
  File "/usr/lib/python3/dist-packages/numpy/__init__.py", line 142, in <module>
    from . import add_newdocs
  File "/usr/lib/python3/dist-packages/numpy/add_newdocs.py", line 13, in <module>
    from numpy.lib import add_newdoc
  File "/usr/lib/python3/dist-packages/numpy/lib/__init__.py", line 8, in <module>
    from .type_check import *
  File "/usr/lib/python3/dist-packages/numpy/lib/type_check.py", line 11, in <module>
    import numpy.core.numeric as _nx
  File "/usr/lib/python3/dist-packages/numpy/core/__init__.py", line 26, in <module>
    raise ImportError(msg)
ImportError:
Importing the multiarray numpy extension module failed.  Most
likely you are trying to import a failed build of numpy.
If you're working with a numpy git repo, try `git clean -xdf` (removes all
files not under version control).  Otherwise reinstall numpy.
Original error was: cannot import name 'multiarray' from 'numpy.core' (/usr/lib/python3/dist-packages/numpy/core/__init__.py)
Saved session recovery to '/home/tmp/quit.blend'
Writing userprefs: '/home/peter/.config/blender/2.82/config/userpref.blend' ok
Blender quit
Linked it back to 2.x
build loaded
    import numpy as np
ImportError:
Blender quit
I believe numpy was loaded by the Ubuntu originally when I built the machine and not a conscious choice on my own.
Postby Aranuvir » Mon Nov 25, 2019 6:17 pm
It's not a bug of MakeHuman or its plug-ins. We cannot fix it. It's a problem of Blender/Linux/Debian/Ubuntu packaging. Please report here: https://developer.blender.org/maniphest ... /type/Bug/
BTW, Blender 2.82 is still rather alpha...
Moving this topic to the blender section.
Postby SaltyCowdawg » Mon Nov 25, 2019 7:02 pm
I was afraid you were going to say that. It was my first hunch. Arrgh...
Thanks anyway.
Postby loki1950 » Mon Nov 25, 2019 9:24 pm
I haven't used any of the distro available packages for years now for any Linux distro they all have behaviour that is not blender standard and they are rarely the latest version get the blender Linux tarbal then extract it to a blender folder that you create in /opt each version of blender then has it's own folder so then you have multiple versions available you do have to create your own menu and desktop launchers though they should point to blender-softwaregl which is a starter script.
Postby SaltyCowdawg » Mon Nov 25, 2019 10:09 pm
Well Joe was right. It was blender packaging and perhaps even a bug with 2.82 itself. I was quite happy to see the human I had in MH pull right in and have the import do all the right things.
Thanks gang.
Return to Blender and MPFB
