New uploads won't download
Postby green_tomato » Mon Nov 27, 2023 9:59 pm
When I'm using the built-in asset downloader under the "Community" tab. Both the new "Ghost" cloth that I uploaded as well as those by user WojackOWL gives me a 404 error. Less recent uploads by other users are working fine.
The requested item failed to download. The server responded with the error code 404 when trying to download http://files.makehumancommunity.org/sit ... ck_Cap.obj.
This is an indication that there is something wrong with the asset on the server, and it should probably be reported to the author of the asset, possibly as a comment on the asset page.
I took a look at the remote.json file, but everything seems normal to me. I tried clicking "Synchronize" again, but got the same result. Here are two examples of links to files from the json file:
File by WojackOWL (not working):
File by squeekimamouse (works just fine):
http://files.makehumancommunity.org/sit ... qun_01.obj
I did manage to do a work-around, where I replaced files.makehumancommunity.org with www.makehumancommunity.org in the remote.json file, and that seems to help temporarily. Is some sort of server side copying not happening?
green_tomato
Re: New uploads won't download
Postby green_tomato » Tue May 21, 2024 3:26 pm
It seems to work again now.
Yay!
green_tomato
Postby joepal » Fri May 24, 2024 5:40 am
Assets are not immediately synchronized to the download mirror, and sometimes there's a hickup in the connection. For a while there, there was a certificate error that prevented the synchronization to happen at all.
Postby joachip » Sat Jul 06, 2024 10:04 am
Two days ago I uploaded the clothes asset "The Moon", but when downloading it from MH, this error shows up:
The requested item failed to download. The server responded with the error code 404 when trying to download http://files.makehumancommunity.org/sit ... e_Moon.obj.
Another issue: It was missing on the clothes page because I had set the clothes sub type to "Other Bodyparts". So now I've changed it to "Hat/Helmet" so that it appears in the list.
joachip
Postby tomcat » Sat Jul 06, 2024 2:34 pm
joachip wrote:Two days ago I uploaded the clothes asset "The Moon", but when downloading it from MH, this error shows up:
Your link, really doesn't open. But the link from The Moon page works fine.
http://www.makehumancommunity.org/sites ... e_Moon.obj
Re: New uploads still won't download
Postby joachip » Fri Feb 07, 2025 11:45 pm
The community downloader in MakeHuman 1.3.0 is still fetching a remote.json file that contains links to files that do not exist (error 404). Here's the last entry:
"3634": {
   "username": "spamrakuen",
   "category": "Underwear",
   "changed": "2025-02-06",
   "uid": 6454,
   "license": "CC0",
   "title": "SR Bikini Top 01 (fused cloth and skin)",
   "created": "2025-02-06",
   "nid": 3634,
   "type": "clothes",
   "compatibility": "1.2.x",
   "files": {
      "mhclo": "http://files.makehumancommunity.org/sites/default/files/clothes/6454/1829760292/sr_bikini_top_01.mhclo",
      "mhmat": "http://files.makehumancommunity.org/sites/default/files/clothes/6454/1271569919/sr_bikini_top_01.mhmat",
      "obj": "http://files.makehumancommunity.org/sites/default/files/clothes/6454/873156392/sr_bikini_top_01.obj",
      "thumb": "http://files.makehumancommunity.org/sites/default/files/clothes/6454/1954693212/sr_bikini_top_01.thumb",
      "render": "http://files.makehumancommunity.org/sites/default/files/clothes/6454/603565825/sr_anime_top_01.png"
   "description": "Another cloth fused with skin experiment.\nIt makes no sense to fuse the cloth with the skin in some parts, btw."
Notice how those links will give an error 404 "not found" in both a browser and in MakeHuman.
joachip
Postby joepal » Sat Feb 08, 2025 4:35 pm
Thanks, I'll take a look at what has happendd.
Postby joepal » Sat Feb 08, 2025 4:39 pm
The host had changed SSH key. I've updated and resynced. Take a look now.
Postby joachip » Sat Feb 08, 2025 6:51 pm
It works! Thank you.
joachip
Postby green_tomato » Sun May 04, 2025 9:14 pm
It's not working for me. (Statue_1 skin for instance). Maybe the automatic sync has stopped working again?
Hack fix: First click "Synchronize" in MH's Community tab, then replace files.makehumancommunity.org with www.makehumancommunity.org in the file C:\Users\blablabla\Documents\makehuman\v1py3\data\community-assets\remote.json
green_tomato
