Need help with mask
Need help with mask
Postby Danewilliams » Fri Apr 17, 2020 12:39 am
I have a problem: I am trying to make a superheroes mask, but when I send it to Makehuman, it doesn't come out right. The ears are sticking out. How do I fix that?
This is what I made for makehuman.
This is what happened
This is how I want the mask to be.
Danewilliams
Re: Need help with mask
Postby Elvaerwyn » Fri Apr 17, 2020 5:11 pm
Allo! The simplest way to pipe this without these areas seen, such as ears- if they are not part of the overall look of the model is to use delete group. If you want a more realistic look that the mask is pulled over the ear tissue just pull the mask away from skull some before porting. Z depth may help here a little bit, possibly add some depth to the mask before hitting make clothes.
Postby Danewilliams » Fri Apr 17, 2020 5:13 pm
Elvaerwyn wrote:Allo! The simplest way to pipe this without these areas seen, such as ears- if they are not part of the overall look of the model is to use delete group. If you want a more realistic look that the mask is pulled over the ear tissue just pull the mask away from skull some before porting. Z depth may help here a little bit, possibly add some depth to the mask before hitting make clothes.
Thank you for that, but I'm afraid I don't understand how.
Danewilliams
Postby Elvaerwyn » Fri Apr 17, 2020 5:34 pm
NP fair enough. Which version of makeclothes are you using out of curiosity, the old one or the new one made by punkduck? In short the delete group is the best choice and this is achieved by assigning the vertexes of the dummy that you wish to be hidden and assigning this as a group to the delete group of vertexes. I hope that made some semblance of sense.
Postby Danewilliams » Fri Apr 17, 2020 8:40 pm
The version I'm using is MakeClothes 2.
Danewilliams
Postby Elvaerwyn » Sat Apr 18, 2020 7:18 am
K that's great, as with that version you can name the delete group anything you like once selected and write the name in the box for this (delete- group on base mesh)
