Hair with gravity
Hair with gravity
Postby joepal » Thu Nov 25, 2010 10:37 pm
I've played around a bit with hair that actually hangs down in animations, independent on which angle the head is held in. These are some quick and dirty results.
Approximate time to model hair (after MHX import to blender) : ten minutes
Approximate time to render: an hour
Crappy youtube version: http://www.youtube.com/watch?v=zkNxcI7iMTk
DVD-resolution render (xvid) : http://www.jwp.se/files/hairdemo.avi
Ok, she should fire her hairdresser, the eyes look kind of spooky with that gaze thing, and hair grows straight through her ears, but it demonstrates the point.
Re: Hair with gravity
Postby Marbury Intermedia » Fri Nov 26, 2010 4:17 pm
That's nice work. Could you try to add more hair segments? It may slow down your render time but should give you a more realistic results. My poor system comes to a crawl when I even think about rendering hair. :)
Marbury Intermedia
Postby Rhynedahll » Wed Dec 08, 2010 10:25 pm
This is modled hair and not particle hair, yes?
The Key to Magic: Book One
Rhynedahll
Postby joepal » Thu Dec 09, 2010 10:16 am
This is blender-internal particle hair only. As far as I know, that's the only way to implement functional gravity, but I might be wrong.
Postby Rhynedahll » Sun Dec 12, 2010 12:10 pm
Are you using 2.49 or 2.55?
Seems like you must be using 2.49 as in 2.55 the particle hair dynamics doesn't work, as far as I know.
Rhynedahll
Postby joepal » Sun Dec 12, 2010 3:03 pm
No, I'm using 2.55 official beta. The particle hair works but bugs a bit. Some strands get locked even though no manual editing (ie "comb" or "cut" etc) has been done.
Postby Rhynedahll » Thu Dec 16, 2010 12:07 am
I'm talking specifically about the Hair Dynamics. With this checked, the hair does not collide with the emitter mesh (the model) but passes right through it.
Unless you figured out how to make this work?
Rhynedahll
Postby ThomasL » Thu Dec 16, 2010 8:49 am
You probably need to enable the mesh as a collision object. However, collision detection takes TIME, so you need an invisible lowpoly object for collision.
There is also the problem that the hair might fall into the skull. This can be fixed by weight-painting the strands; the root should be red and the tip blue.
ThomasL
Postby joepal » Thu Dec 16, 2010 10:10 am
I did none of the above for this particular video. I just tweaked the various forces (emitter tangents, gravity...) so that the hair would look like a common haystack.
I'll redo the hair demo eventually, I've figured out a better scheme for making reasonable haircuts (without combing/cutting) by defining a few extra vertex groups.
Postby Rhynedahll » Thu Dec 16, 2010 1:11 pm
ThomasL wrote:You probably need to enable the mesh as a collision object.
This I know. :D
I just tested the lowpoly idea with an iconosphere and a cube. When using the Hair Dynamics, the hair particles do not collide with anything.
When using a vertex group (for example an area of the head designated as Scalp) to control density of the emitted hair particles, and Hair Dynamics, Blender 2.55 automatically weight paints the vertex group and the strands.
I also tested this with an iconosphere.
1) I weight painted the entire object to 1 (red) to see if it made any difference. The hair particles did not collide with the mesh at all but simply fall straight through.
2) Weight painting the hair particles to (a) all red and (b) red at root and all blue make no difference. The hair particles do not collide with anything.
The Hair Dynamics tab, when checked, makes the hair behave like real hair, except for the problem of no collision. I've posted on the Blender Artists forum about this and others have also encountered the problem, but no one has yet figured out how to fix it.
The general supposition is that the feature has not yet been completed, i.e. no collision check.
Rhynedahll
Users browsing this forum: No registered users and 12 guests
