Make Clothes more help
Postby fake_Person » Wed Dec 09, 2020 11:00 pm
Going to need some of these errors in the Make clothes
14 year old deadbeat http://www.makehumancommunity.org/forum/ucp.php?i=profile&mode=signature#
fake_Person
Re: Make Clothes more help
Postby jwc » Thu Dec 10, 2020 6:17 am
The error message says you are trying to use a mesh that has a face with more than 4 vertices.
Makeclothes cannot handle this.
In Blender, edit mode, select a single face on your clothing item and look at the information about what you have selected.
It should say: 1 face, 4 edges, and 4 verts.
To find the offending faces:
Select Similar, Polygon Sides
This will select all the good faces with 4 edges.
Then
Hide Selected
and what is left are faces with other than 4 verts.
These faces must be modified, how to do that depends on your topology.
Adding more faces and working toward edges or merging adjoining faces usually helps.
jwc
Postby punkduck » Sat Dec 12, 2020 4:04 pm
well after pressing "check clothes" the rewritten code also selects the faces with the problems ... at least if I didn't do errors again ;)
So simply switch to edit mode, they should be highlighted.
