exporting in MakeHuman SVN
Postby yumri » Tue Feb 05, 2013 2:11 am
In simple nothing exports in MakeHuman SVN r4538. I have tried every export format and the only one which works in that SVN version and all the versions down to and probably before MakeHuman SVN r4523 cannot export what is made in MakeHuman.
This is a problem as MakeHuman is a tool to be used to make characters for games and stuff in which it does a really really good job at don't get me wrong it does. The Issue of not being able to export does not extend to Saving the file as a MakeHuman .mhm file to later on loading it up. In which I have done before though I am pretty sure that Blender and Unity3D cannot open .mhm but can with .mhx . Blender being the 3D engine which I prefer currently working with the official stable release of Blender 2.65a . So please someone tell me how to get MakeHuman to export the human 3D models again.
yumri
Re: exporting in MakeHuman SVN
Postby tjindy » Tue Feb 05, 2013 8:38 am
It is known issue. You have to be patient. Devs should sometimes rest too ;)
Regards
TJ
tjindy
Postby 2ndclemens » Tue Feb 05, 2013 10:22 am
As A workaround I have two versions running and copied the clothes library from the most recent to a still "exporting" version. So I can export the Jacket and the better fitting Clothes.
The Jeans however was missing some Data (uvs?) so I copied that from an older version straight into the file...
2ndclemens
Postby ThomasL » Wed Feb 06, 2013 5:55 am
Is this problem still there? I don't have any problems to export from r4554
ThomasL
Postby tjindy » Wed Feb 06, 2013 3:18 pm
Thanks Thomas, everything works fine :)
Export works perfectly, import to blender too.
Regards
TJ
tjindy
Postby 2ndclemens » Wed Feb 06, 2013 7:35 pm
Yes, it works now thanks a lot!
Only when you dress the character with jeans_medium export to blender is aborted.
I think some data is missing at the end of the jeans_medium.mhclo.
I copied all data after "# texVerts 1" from an older version into the file and then it works.
This is the error message:
File "./core\events3d.py", line 195, in callEvent
method(event)
File "./apps\gui\guiexport.py", line 86, in onFileSelected
exporter.export(gui3d.app.selectedHuman, filename)
File "plugins\9_export_mhx.py", line 90, in export
mh2mhx.exportMhx(human, filename("mhx"), options)
File "./apps\mh2\mh2mhx.py", line 30, in exportMhx
mhx.mhx_main.exportMhx(human, filename, options)
File "./shared\mhx\mhx_main.py", line 108, in exportMhx
exportMhx_25(info, fp)
File "./shared\mhx\mhx_main.py", line 184, in exportMhx_25
proxyCopy('Clothes', info, fp, 0.4, 0.6)
File "./shared\mhx\mhx_main.py", line 209, in proxyCopy
copyFile25("shared/mhx/templates/proxy25.mhx", fp, proxy, info)
File "./shared\mhx\mhx_main.py", line 285, in copyFile25
writeProxyMesh(fp, info, proxy)
File "./shared\mhx\mhx_main.py", line 731, in writeProxyMesh
writeProxyMaterial(fp, mat, proxy, info)
File "./shared\mhx\mhx_main.py", line 871, in writeProxyMaterial
info.config)
File "./shared\mhx\mhx_main.py", line 833, in writeProxyTexture
texname = info.name + os.path.basename(tex)
AttributeError: CExportConfig instance has no attribute 'name'
2ndclemens
Postby ThomasL » Thu Feb 07, 2013 6:36 am
Should be fixed in r4568.
ThomasL
Postby 2ndclemens » Thu Feb 07, 2013 7:36 pm
Confirmed! All is well now, thanks again MH Team.
2ndclemens
Postby aay9203 » Thu Feb 14, 2013 1:39 am
Is there an mhx exporting issue in r4642? I couldn't export and got a similar error to the error listed above.
aay9203
Postby ThomasL » Thu Feb 14, 2013 4:56 am
For me there is no obvious error with r4653. Can export standard nude character to collada, mhx, fbx and obj with default settings. Md5 and stl export is broken though.
What is the error message in the console?
ThomasL
