A realitic vagina
Re: A realitic vagina
Postby joepal » Wed Jul 05, 2017 7:55 am
The proxies are still in the same location as two replies up: http://www.makehumancommunity.org/proxies.html
Postby ShadoWraith75 » Thu Jul 06, 2017 3:55 pm
Sorry about that; I was trying to do things the wrong way. I had downloaded them without being in the program, and had messed it up. Once I synched up and downloaded them in the Community tab, got them to work correctly. Now just to get the interior done correctly to match up; thanks!
ShadoWraith75
Re: A realistic vagina / penis
Postby jeanroman » Thu Nov 23, 2017 11:40 pm
I am using MH version 1.1.1 on a macbook pro
I am unable to access or see female genitalia
I have downloaded genitalia from
on a mac to access DATA/proxymeshes you have to right click on they application ikon then select show packages
after I put the downloaded genitalia files into the proxymeshes folder - I am still unable to see any female genetalia and I cannot manipulate the male genitalia sliders - they do not move at all
please help me figure out what to do to make a model with genitalia
jeanroman
Postby loki1950 » Fri Nov 24, 2017 3:20 am
The male genitalia sliders only work if you also get the male genitalia proxy as well and you do not need to put the proxy with the program data it can be put in the makehuman folder that is in your home folder the full path should be /home/username/makehuman/v1/data/proxymeshes
Postby jeanroman » Fri Nov 24, 2017 3:56 pm
"Re: A realitic vagina
Postby loki1950 » Thu Nov 23, 2017 10:20 pm
Enjoy the Choice :)"
LOKI950,
can you please link me to the correct "male genitalia proxy" file/folder that I need to put into the proxymeshes folder
I downloaded genetalia from this link:
and put them into my proxy meshes folder - none of them work
this is what I have in my proxymeshes folder now:
clear.thumb * (default in v. 1.1.1)
Adult Female Genitalia
Adult Female Genitalia (new) HEALED
Adult Female Genitalia (old)
Adult female genitalia remapped
Adult Male Genitalia
Female muscular with simplified genitals
female_generic * (default in v. 1.1.1)
female_muscle_13442 * (default in v. 1.1.1)
female1605 * (default in v. 1.1.1)
male_muscle_13290 * (default in v. 1.1.1)
male1591 * (default in v. 1.1.1)
penis01
proxy741 * (default in v. 1.1.1)
vag01
* default folder/files that where inside the proxymeshes folder upon download of MH v.1.1.1
which of these files is the " male genitalia proxy" that you refer to in your reply:
jeanroman
Postby jeanroman » Fri Nov 24, 2017 4:06 pm
loki1950 wrote:The male genitalia sliders only work if you also get the male genitalia proxy as well and you do not need to put the proxy with the program data it can be put in the makehuman folder that is in your home folder the full path should be /home/username/makehuman/v1/data/proxymeshes
LOKI,
please link me to the "male genitalia proxy file you refer to
and why can't I see a female genitalia option?
jeanroman
Postby punkduck » Fri Nov 24, 2017 8:16 pm
jeanroman wrote:
LOKI,
If you use a Linux box, Lokis method will work.
On a Mac (at least on my Mac) MakeHuman shares the Documents folder with other applications (with e.g. Blender). Your directory is
/Users/<yourloginname>/Documents/MakeHuman/v1/data/proxymeshes
In this directory you have to put the .obj and .proxy file (and the .thumb), both files together will create the mesh. If you see a .mhpxy and .npz file in this directory also, the system has used the proxy at least one time.
In the .proxy file is a line "tag genitals". This simple text line is used to enable the sliders, no rocket science used :D
For the clothes it is similar. You have a .mhclo instead of the .proxy and the path is
/Users/<yourloginname>/Documents/MakeHuman/v1/data/clothes
So everything you download or create yourself you have to put in your own MakeHuman directory.
If you are interested: the internal directory of the application is /Applications/MakeHuman.app/Contents/Resources. The structure of the data path inside this directory is the same as mentioned above, but here you will find the "original" skins and clothes.
Modern versions of the Mac finder often hide the system-paths (/Applications) or do not present the suffixes like .proxy ... I'm an Apple user and I hate that, so I do most with the terminal like the UNIX guys ...
For females you can always change the breastsize even without the proxy, for the vagina we don't have sliders by default. We have some user targets (which create these sliders) to change position or size, but these targets are working on the non-proxy version also. So there is nothing special for females.
Postby supremedemon123 » Fri Apr 26, 2019 5:10 pm
can someone help me
i am trying to create a lolicon art piece for my personal use, but cannot figure out the way to give this loli her anatomically correct genitals.will someone please help or point me in the right direction? thanks.
if someone has a problem with this statement, just know that for the same reasons YOU care about this topic, i couldnt give a flying rats rear end.
supremedemon123
Postby loki1950 » Sat Apr 27, 2019 3:20 am
Have you bothered to actually read this whole thread if you had your question becomes meaningless because it would have answered just what you asked so it has 8 pages with all info you need in one place besides if you had used the forum search function there are several other threads with the same details.
