Skins - UV BASE map for ?
Postby alex_farlie » Fri Oct 25, 2019 8:39 am
I was wanting to attempt to create a custom skin for Make Human. (My intended base model is attached.) (The idea was to create a sci-fi character, partly inspired by the origin story of the Cybermen in Doctor Who. My thought was to consider what you would get if you had Cyber-femme instead? :lol: )
Would it be possible for a Makehuman user to provide a suitable UV map (prefferably in a 2K(2048x2048) or 4K(1096x4096) size, so I can use that as a base for constructing the skin as Vector artwork in Inkscape ( possibly with meshes?), That could then be exported.
Alternatively, is there a specialist standalone MakeSkin tool, to enable re-skinning based on arbitary underlying tectures?
Please note that the attached model uses the custom Robot01 target contributed by Grinsegold (which is available under the CC-BY license from the Make Human asset repository.)
Cyberfem.zip
Intended base model..
(4.99 KiB) Downloaded 728 times
alex_farlie
Re: Skins - UV BASE map for ?
Postby punkduck » Fri Oct 25, 2019 7:53 pm
Hmm, to be honest, no matter what you do inside MakeHuman, it does not change the given UV-Map. Only a proxy can have an own different one. So you definitely "only" need to take one of the skins and draw an own one on it (use another layer in GIMP, photoshop, inkscape).
In the assets you will find the annotated skin from Joel Palmius. Or you export the character into blender, select the mesh call the uv editor. It will be shown there when you select the skin.
The easiest way if you only want to paint it (believe me that's the way how I started with my characters ;) ) is; download the annotated skin and then exchange/overwrite the image Joel did.
Technical background: the coordinates of the UV-map are in the base.obj file, the lines look like this
vt <x-value> <y-value>
The x and y values are the coordinates in an image of size x=1/y=1, so 0.5/0.5 is in the middle. When you add a 4k or 8k or 0.5k picture it works identically, only the resolution changes. Each of these lines correspond to a line starting with v and then the x,y,z coordinates, which are the real vertices. base.obj comes with makehuman (mostly compressed as base.npz) and is not changed.
A more complicate way is doing that after exporting it to blender, especially when you expect distortions or sth because the target deformed parts you want use. Then you can do your own UV layout. You have to create seams on the body, do an UV unwrap and then you can add an own texture. But this is an advanced method and needs some experience (because of the projections) etc. in Blender.
Postby Elvaerwyn » Sat Oct 26, 2019 10:55 am
Here go bud this should get you going (I hope) they are done in 2k and exported from blender. There is base mesh, female, male and all included.
uvunwraps_mhdummies.zip
unwraps zipped 2k
(15.06 MiB) Downloaded 819 times
Postby alex_farlie » Sat Oct 26, 2019 4:44 pm
Elvaerwyn wrote:Here go bud this should get you going (I hope) they are done in 2k and exported from blender. There is base mesh, female, male and all included.
Thanks although in testing the skin I was drawing, I'm finding bug after bug relating to my video cards inablibity to cope with BASIC modern Open GL. :evil: (Sigh). I need a new computer :(
alex_farlie
Postby ChenDirit » Thu Jun 03, 2021 6:12 am
If you made the texture to tile according to the UV map then keep in mind the following: - Texture should be 2048x2048 - Set offset X, Y, and rotation to 0 - Tick "ignore\_weapon\_size\_scale". The texture should then tile correctly following the pattern lines of the UV sheet. Hope this helps!! I usually do this to mine and it works. Anyways where can I sell csgo skins cause I need a good profit off of them. I have a large variety of skins and I want to sell them all and quit playing the game.
ChenDirit
Postby MTKnife » Thu Jun 03, 2021 11:06 pm
The proxies (e.g., the ones with genitals) do have different UV maps--so be careful which you're using.
MTKnife
Postby Cooper83 » Thu Aug 19, 2021 5:00 pm
I am very far from sports in general.
Cooper83
Postby alex_farlie » Tue May 03, 2022 11:07 pm
Thanks again for making these. Would it be possible to get these added to the community assets as an SVG file as well? ( Apparently recent Blender versions can export a UV mapping as Vector. I can then use the 'node' as snapping points, for drawing a design, setting up mesh fills..)
alex_farlie
