MakeHuman 1.0 alpha6 source code
Re: MakeHuman 1.0 alpha6 source code
Postby mflerackers » Wed Apr 20, 2011 2:43 pm
You build it, I don't think it's supplied by the installer. Run scons to build on linux, or on windows if you use visual studio.
MakeHuman project Developer
mflerackers
Postby nchandol » Mon Aug 01, 2011 5:59 pm
how you have downloaded the source code in your machine?
nchandol
Postby nchandol » Tue Aug 02, 2011 2:20 pm
I also have the same problem, can't find the mh.pyd file. I run it in macosx, does anybody have any idea how to use the mh module? I tried to do all the above but it doesn't work.
Please any help???
nchandol
Postby Manuel » Fri Aug 19, 2011 1:26 pm
nchandol wrote:I also have the same problem, can't find the mh.pyd file. I run it in macosx, does anybody have any idea how to use the mh module? I tried to do all the above but it doesn't work.
Please any help???
You have to compile the c code in order to make the mh.pyd.
Best,
Postby HoraxHon » Thu Oct 15, 2020 7:03 pm
Now I have the same question: where can I download the source code of MakeHuman 1.0 alpha 6? :? The old link is dead. :(
HoraxHon
Postby loki1950 » Thu Oct 15, 2020 11:10 pm
Why would you want a version that is several years old with very limited utility instead of our latest code ?
Postby HoraxHon » Fri Oct 16, 2020 4:03 am
Because of that old version is exactly what I need and it's limited utility can be expanded.
One more time: I will be very happy if anybody helps me to download these source!
HoraxHon
Postby Elvaerwyn » Fri Oct 16, 2020 6:39 am
Postby HoraxHon » Fri Oct 16, 2020 7:31 am
Thank You for your attention, but the windows version presented here has no any code :( - only release (is used by me).
As I understood - after many hours - all the sources are in the linux packages. THANKS! :D
HoraxHon
Postby Elvaerwyn » Fri Oct 16, 2020 4:41 pm
Cool Glad you found what you need! GL :D
Return to Python scripts
