I have some old modes created using the previous versions.
I am unable to open them. They are .mhm.
1.2.0 cannot open them.
Any suggestions or workaround to this?
I am using Ubuntu Studio 18.04.
"realtimeUpdates": true,
"restoreWindowSize": true,
"sliderImages": true,
"loaddir": "/data/punkduck/makehuman/v1/models",
"excludePlugins": [],
"rtl": false,
"invertMouseWheel": false,
"lowspeed": 1,
"language": "english",
"savedir": "/data/punkduck/makehuman/v1/models",
"GL_RENDERER_AA": true,
"Scene_Editor_FileDlgPath": "/data/punkduck/makehuman/v1/data/scenes",
"rendering_width": 2000,
"cameraAutoZoom": false,
"preloadTargets": true,
"rendering_height": 1500,
"GL_RENDERER_SSS": true,
"realtimeFitting": true,
"exportdir": "/data/punkduck/makehuman/v1/exports",
"version": "1.1.1",
"highspeed": 5,
"realtimeNormalUpdates": false,
"units": "metric",
"guiTheme": "makehuman",
"windowGeometry": {
"y": 25,
"width": 2560,
"state": [
"maximized"
"height": 1391,
"x": -1
Maybe the path simply points to the old folder
Aranuvir wrote:Any suggestions or workaround to this?
Yes, post the error logs...
joepal wrote:And the contents of the mhm files. They are plain text files, so can be opened with any text editor.
punkduck wrote:just a silly question from my side, I remember I had trouble when I changed back from Apple to Linux (I also use Ubuntu 18.04 now). I simply copied a file called settings.ini and of course I have a different home path on my Linux box compared to Apple before: there are at least a few potential problems inside the settings.ini ... I will simply add my MakeHuman 1.1 one as an example.
- Code: Select all
"rtl": false,
"lowspeed": 1,
"version": "1.1.1",
"highspeed": 5,
"units": "metric",
"windowGeometry": {
"y": 25,
"width": 2560,
"state": [
"maximized"
"height": 1391,
"x": -1
there are few paths causing trouble as you can see. In my case it was the new home directory, now a copy will have some hidden problems with pathes called v1py3 instead of v1. Maybe the path simply points to the old folder ...
