['pose' problem]
'Apose_ue' calculates the angle of the bone from lower arm to finger and rotates the difference from Unreal's A-pose. For the other bones, the angles are adjusted visually and manually. This time I made a pose that rotates from upperarm to finger by the calculated angle and does nothing else.(Apose_ue20200801.bvh)
Perhaps the middle pose of the two poses may be the best, but I would like to hear your impression.
You may know the storage location, but it is shown just in case.
Documents - makehuman - v1py3 - data - poses
['anchor' problem]
It looks like the weights are weird. But I can't imagine the cause. I'm using sockets for makehuman to blender imports, are you the same? If not .mh2?
Write down all the export settings from blender to unreal engine.
Path Mode : Auto
Batch Mode : Off
Include
Selected Objects : uncheck
Active Collection : uncheck
Object Types : select all
Custom Properties : uncheck
Transform
Scale : 1.00
Apply Scalings : All Local
Forward : -z Forward
Up : Y Up
Apply Unit : check
!EXPERIMENTAL! Apply Transform : uncheck
Geometry
Smoothing : Face
Export Subdivision Surface : uncheck
Apply Modifilers : check
Loose Edges : uncheck
Tangent Space : uncheck
Armature
Primary Bone Axis : X Axis
Secondary Bone Axis : -Z Axis
Armature FBXNode Type : Null
Only Deform Bones : uncheck
Add Leaf Bones : uncheck
Bake Animation : uncheck
I will also post the latest version of the Python script. The processing hasn't changed much, so I don't think it will affect it.
