female genitals
female genitals
Postby Newer » Sun Jan 06, 2019 1:53 pm
okay here is the deal one tutorial said put everything in a folder in Documents\makehuman\v1\data\proxymeshes\adult_female_genitalia_healed so did that and no sliders show up in modeling gender genitals on makehuman.exe i have the latest stable version 1.1.1. what do i have to do to get the sliders to show up :x
Newer
Re: female genitals
Postby joepal » Sun Jan 06, 2019 3:07 pm
There are no official sliders for female genitals per se. The only official genitals sliders around are a few for penis. You can try to use custom targets from http://www.makehumancommunity.org/targets.html, for example http://www.makehumancommunity.org/targe ... ialia.html. Frankyaye has put a few female genitals targets there.
Re: female genitals
Postby Newer » Sun Jan 06, 2019 3:10 pm
a bit strange one for one gender only and not the other :?:
Newer
Re: female genitals
Postby joepal » Sun Jan 06, 2019 3:17 pm
The penis sliders are pretty primitive too. Since no-one in the MH team had any use for or were interested in these sliders, other things were prioritized.
These days, we're deferring most target requests to the user contributed assets (you can make a request here: viewforum.php?f=20), since the quality of those submissions are often better than if the dev team had tried to do something similar.
Re: female genitals
Postby wolgade » Mon Jan 07, 2019 5:16 pm
Newer wrote:a bit strange one for one gender only and not the other :?:
The technical explanation is quite simple. All sliders (targets) are shapekeys for the base mesh. The base mesh does not include genitals, but a penis helper, which is very basic. You simply can't have sliders for geometry that doesn't exist.
Re: female genitals
Postby Jogi60 » Sat Nov 16, 2019 1:26 pm
Hello, I am new in this program. How can I use the files "Targets"? I have tried to download it but no success. What must I do or how must I install it to use??
Thamk you
Jogi60
Re: female genitals
Postby joepal » Sat Nov 16, 2019 1:42 pm
Maybe this helps?
https://www.youtube.com/watch?v=ra_pkb9IdeI
(you don't need to download targets manually, there is a function for it inside MakeHuman)
Re: female genitals
Postby Jogi60 » Sat Nov 16, 2019 2:30 pm
Thank you, work perfect
Jogi60
Re: female genitals
Postby Little+White+Shark » Fri Dec 27, 2019 8:49 pm
Saludos a todos,soy nuevo en este foro y hace muy poco que me descargué MakeHuman.Mi impresión no puede decirse que sea buena,tiene bastantes cosas y se pueden añadir más,pero lo que me subleva es que algo tan básico en la anatomía humana como son los genitales no aparezcan por defecto en la aplicación.Las barras deslizadoras para los genitales masculinos no pueden moverse,aunque he visto por aquí que hay un complemento para ponerlo y los femeninos ni aparecen.Sí,ya sé que luego les ponemos ropa y se les disimula,pero nuestras creaciones están incompletas y tristes.
Solo pedirles a los creadores de este software que se acuerden de poner esa parte tan esencial del cuerpo en la próxima versión.Muy agradecido
Little+White+Shark
Re: female genitals
Postby loki1950 » Thu Jan 02, 2020 9:31 pm
Doing so would make our software a crime to use in over 50 countries so the reasons are international law not any other as is even nipples are censored in some countries the genitalia are available from our online asset repo which if you download them is your responsibility not ours but making them available leaves us very open to litigation in those countries some even demand a death penalty as it is equated to porn production.
