Now it is pyOpenGL that does not work.
At least you're getting closer
The type of error is different too, it no longer says "DLL is no valid win32 application", now it says "I cannot find your DLL file":
- Code: Select all
ImportError: DLL load failed: The specified module could not be found.
So pyOpenGL is either not, or not correctly installed, it's not installed in your python/system path or your python/system paths are not properly set up to make it find the DLL.
