User Defined functions in makehuman
Postby Shreyansh_Dubey » Fri Sep 28, 2018 6:14 am
How can i use Python 2.7 functions which are user defined in Makehuman shell as well as in scripts?
I want to create some functions involving loops and they would include some Python 2.7 predefined functions as well as some Makehuman mhapi functions, that I can call directly in makehuman scripting. Where should i save any such function so that it is accesible in script as well as in Makehuman shell.
Please guide me.
ThankYou
Shreyansh_Dubey
Re: User Defined functions in makehuman
Postby joepal » Fri Sep 28, 2018 9:05 am
I'd say the most efficient way would be writing a new plugin, which extends MHAPI on load.
In a file called for example "9_myuserfunctions.py" placed under "plugins":
#!/usr/bin/python2.7
# -*- coding: utf-8 -*-
from core import G
# The reason for the folloring arcane snippet is that python
# refuses to import from modules with a name that starts
# with a number.
mhapimodule = __import__("1_mhapi")
try:
    attrlist = mhapimodule.__all__
except AttributeError:
    attrlist = dir (mhapimodule)
for attr in attrlist:
    globals()[attr] = getattr (mhapimodule, attr)
# Extending Namespace is stricly speaking not necessary, but it's the structure
# that the rest of MHAPI follows. In __init__ we'll also make a convenience assignment
# so you can access the whole of MHAPI via "self.mhapi" in all the methods.
class MyUserFunctions(namespace.NameSpace):
    def __init__(self,api):
        self.mhapi = api
        namespace.NameSpace.__init__(self)
    def oneOfMyFunctions(self):
        print("I'm alive!")
def load(app):
    G.app.mhapi.myuserfunctions = MyUserFunctions(G.app.mhapi)
def unload(app):
    pass
Now, after startup, you can call this like any other MHAPI module. For example in the shell tab:
from core import G
G.app.mhapi.myuserfunctions.oneOfMyFunctions()
... will respond by printing "I'm alive"
Postby Shreyansh_Dubey » Mon Oct 01, 2018 7:18 am
Thankyou :P :geek:
Shreyansh_Dubey
Return to Python scripts
