Control Clothing Stacking Order?
Postby Atom » Thu Sep 13, 2018 11:00 pm
Is there a way to control the clothing stacking order?
I want the sweater to be on top of the skirt?
Sweater skirt issue.
Atom
Re: Control Clothing Stacking Order?
Postby wolgade » Fri Sep 14, 2018 11:25 am
I don't think there's anything like a stacking order. If you want the shirt on top of the skirt you'll have to fix this after import. Even more annoying: You might have to do this again when you change the pose.
Postby bogdan666 » Fri Sep 14, 2018 1:08 pm
The only way will be to resculpt the sweater in blender in such a way that it covers the skirt like it does in real life (or cover the sweater with the skirt) or remove/compress the bottom part of the sweater.
bogdan666
Postby MTKnife » Sat Sep 15, 2018 4:58 pm
I think in principle this problem is solvable, and it's something I'd like to do, but I haven't gotten around to it yet
MTKnife
Postby Freehunter » Sat Sep 15, 2018 11:25 pm
Possibly the z_depth in the .mhclo file could be changed in the related clothing items. Things closest to the body lower numbers, farther away higher. Don't remember the allowed range. This can also be set in makeclothes when creating new clothes.
http://www.makehumancommunity.org/forum/viewtopic.php?f=7&t=2155&p=8772&hilit=z_depth#p8772
Freehunter
Postby MTKnife » Sun Sep 16, 2018 2:17 pm
I don't think the Z-depth has any effect unless delete groups are set.
MTKnife
