Human in aplication without color
Postby tarabaz » Fri Aug 14, 2009 1:36 pm
I'am using the Builds from Joepals Site. Since some Revisions the Human in 3d view is only black (like a shadow). My os is Debian Sid. With a build from last week, everything works fine.
I like the way the workflow of hamehuman is going and i hope, that this time makehuman will be finished befor you guys rewrite and redesign everything from zero ;)
And befor i forgot it: sorry for my bad english, its not my nativ language.
tarabaz
Re: Human in aplication without color
Postby mflerackers » Fri Aug 14, 2009 1:59 pm
Daily SVN builds are not as stable as version builds. It looks like GLSL shaders are turned on in your build, and it seems your pc has a problem with them. Look in human.py, there should be a line:
# Uncomment the following 3 lines to use a shader
comment the 3 lines following that line and try again.
MakeHuman project Developer
mflerackers
Postby tarabaz » Sat Aug 15, 2009 12:55 pm
thanks for your reply, it solves the problem.
yes, my graphiccard don't support glsl, i'am not a fan of computergames so it was never a problem. but since blender supports glsl for realtime preview i think it's a good time to buy a new one.
tarabaz
Postby mflerackers » Sat Aug 15, 2009 1:07 pm
So it seems I need to adapt my code to check if glsl will work, normally it should have fell back to non shader rendering :)
mflerackers
