Alpha 8 and high poly eye -- texturing
Postby SaltyCowdawg » Wed Sep 04, 2013 3:31 pm
So.. what's the trick? All I can get is black orbs inside the eye socket. Or worse all white "zombie eyes."
Re: Alpha 8 and high poly eye -- texturing
Postby Manuel » Wed Sep 04, 2013 3:33 pm
You should better describe what you are doing. What system are you using, and add a screenshot and the log.
Postby SaltyCowdawg » Wed Sep 04, 2013 3:52 pm
OK.. when I get home later tonight I will post something more complete. Hoped it would be a quick answer.
Here's the highlights of what I'm doing:
Blender 2.6x using Cycles
Node setup where I'm using the eye color PNG file that gets exported for the eye as an image texture
Adding in glossy shader with image texture as input
Not getting anywhere near the results I'd have expected. I'm posting this from work and don't have access to my blend file at the moment.
Postby Manuel » Wed Sep 04, 2013 5:07 pm
So the problme is not in MH, but in Blender, after you export/import the model?
Postby SaltyCowdawg » Wed Sep 25, 2013 2:51 pm
Sorry it took so long to get back to this... but here is what I was referring to:
I used the eye color image to texture the eye. Looked at the UV and it looked good but the eye does not render correctly in Cycles.
Postby Manuel » Wed Sep 25, 2013 2:56 pm
Maybe normals are inverted?
Postby SaltyCowdawg » Wed Sep 25, 2013 8:03 pm
I've included the blend file. I'll take a look myself when I'm (finally) home tonight. Hope I remembered to pack the textures.. :-)
Postby ThomasL » Thu Sep 26, 2013 2:30 am
Looks like the cornea has lost its transparency.
ThomasL
Postby SaltyCowdawg » Thu Sep 26, 2013 3:41 pm
I'm not sure why I didn't think of this earlier but I messed around with adding an alpha to the mix.
node setup in cycles for Lilibeth's green eyes
This produced much better results as here:
Rendered Lilibeth with alpha mask
There are still strange artifacts that I have not been able to figure out how to get rid of, or where they are coming from.
