Custom target file.
Re: Custom target file.
Postby Manuel » Sun Aug 18, 2013 7:50 pm
Rapscallion wrote:Muchos Gratcias. This method works very nicely.
If you notice other big lacks, I'll be glad to add your files to official version.
In that case, the "specifications" are:
1) Include helpers in the transformations.
2) Create 2 targets, with opposite effect.
Postby Rapscallion » Sun Aug 18, 2013 10:09 pm
Thanks Manuel, I will consider what you have said if I notice anything further that will add significantly to MH.
Rapscallion
Postby Rapscallion » Tue Aug 20, 2013 6:58 pm
Mmmm, I have a question.
How do I include helpers in the transformations?
If I 'Load Human + Fit Tools' I get a lot of vertices covering each other.
Difficult to edit.
Rapscallion
Postby Manuel » Tue Aug 20, 2013 10:03 pm
You can select the vertices with L-key, or by material, and then hide them with H-key.
I usually hide all helpers, modify the human, then ALT-H to show helpers and fit them.
There are other rules, like not deform the joint helpers, and move them in the correct location for joints.
For this purpose is very useful the proportional edit tool that affect "connect only" vertices.
It would be good to have a tutorial about it, but unfortunately we haven't it yet.
Postby Rapscallion » Tue Aug 20, 2013 10:45 pm
Ok, thanks for your advice Manuel.
Rapscallion
