Hi, I just downloaded Makehuman and I am excited about this piece of software, I can tell.
I saved my first creation as an .obj file. Anything worked fine up to there.
Then I imported the object to vue 6 esprit and tried to apply materials and to render it.
What happens then is that the rendering of the surface seems to leave out certain areas. I attached an image, where you can see this effect. There are some black spots coming from the back and underneath the breasts.
This may be due to some bug in Vue, though I thought I had better ask here, if this occurs in other softwares as well, or if the problem is known and there is any work around... I tend to think, that the .obj file has some sort of an error, because the spots under the breasts are exactly those, that already look weird in the MakeHuman Preview and I have never had any such problems in Vue.
There is a second weird thing.. if I assign a material in vue (this is just something that will make the surface look in a certain color and with a certain amount of reflection etc.) the entire body will be effected by this except for the head. Is this normal... is the head somehow stored separately?
Does anyone know anything about these problems or can help me... I would love to play around a little with MakeHuman.
Thanks for the help, and congratulations for this excellent software.
Best Regards,
Philipp
