Synchronous Redraw?
Synchronous Redraw?
Postby Fodderine » Tue Nov 08, 2011 8:49 am
It's me again :oops:
I can't figure out how to perform a synchronous redraw (i.e. finish opengl render before proceeding) inside a plugin.
Is it also possible to perform a openGL "grabScreen()" at a custom resolution?
Fodderine
Re: Synchronous Redraw?
Postby mflerackers » Tue Nov 08, 2011 8:56 am
self.app.redrawNow()
self.app.scene3d.grabScreen(x, y, width, height, os.path.join(grabPath, 'grab.bmp'))
MakeHuman project Developer
mflerackers
Postby Fodderine » Wed Nov 09, 2011 6:39 am
Thanks Marc. redrawNow(); works great
The intent of the grab screen was to get a higher resolution output from openGL.
Say my window was running at 800x600, I want to obtain an output around 2400x1800 px.
I have worked around this before by specifying in C code to launch at a huge resolution, but this seemed like a dumb way of doing it :lol: .
Could I send a "resize event" programmatically so that makeHuman is only enlarged when I need to capture the output? Or is there an even easier way of doing this.
Fodderine
Postby mflerackers » Wed Nov 09, 2011 1:14 pm
I guess in windows you can just call SetWindowPos with the hwnd of the makehuman window. You can get the hwnd by caption ("MakeHuman - [Untitled]" if not loaded or saved) or class ("SDL_app") or just take the first (and only) hwnd of the process.
Rendering to frame buffer (fbo) is planned, though not supported yet, so you can only get what's on the screen.
mflerackers
Return to Python scripts
