Rotate bone along local axis
Posted:
Wed Jun 14, 2017 11:50 am
by ShatteredEssence
How do i rotate say finger2-1.R by 45 degrees along X. Screenshot from skeleton debug included
Re: Rotate bone along local axis
Posted:
Sat Jun 24, 2017 3:34 am
by RobBaer
This is done in a downstream program of your choosing. It can not be done in MH skeleton debug which is a utility included in build versions for viewing weight painting, not rotating joints.
For example in Blender you might select the bone and hit the R key. Using local rather than global axes can sometimes help. If you import with the mhx2 control rig, I believe you can hit s with the finger control and move all the bones of a finger together.
