Texture image of bone weights
Postby AndyM » Mon Oct 05, 2015 9:59 am
I am working on an extension of the Skeleton Debug Plugin (debugtab.py). For that I would need a texture image of the calculated bone weight colors.
I understand how the weights are converted into colors and assigned to the mesh. Also I found the UV mapping.
But I can not figure out how the texture image is calculated from this?
AndyM
Re: Texture image of bone weights
Postby duststorm » Mon Oct 05, 2015 2:15 pm
I'm not using a texture for it, I'm using vertex colors, that I either enable as diffuse color in the fixed function pipeline, or pass to the shader (the shaders multiply the diffuse color with the vertex color, interpolated per texel).
Return to Python scripts
