Making touchable soft body physic for humanoids in real time
Postby PRAKHAR » Mon May 08, 2017 5:13 pm
Hello friends,
Blender is hitting the arena of animation nowadays.
Physics which is used in this software is really game changing, helps us a lot during our modeling & animation Soft Body
is a very nice tool which helps us in modelling our daily objects like wires, spring, leather, plastics, strings, rubber etc. Even human beings, Weight Paints plays epic role in this.
So, I need help in creating such weight paint for humanoids (female) which can be used in its soft body
Soft body examples for skin touches animation (ignore c, g & h)
PRAKHAR
Re: Making touchable soft body physic for humanoids in real
Postby wolgade » Tue May 09, 2017 1:54 pm
This is a very long shot. A while back I used soft bodies to animate female breasts which worked quite ok. For your examples you'd need two things: A very high poly human mesh to allow for the deformations shown and a lower poly control mesh (cage) where you actually run your softbody simulation on. The simulated cage deforms the human mesh by using a mesh deform modifier. By using two meshes you get smoother deformations. In many cases you also need something else: A way to preserve the volume of the deformed human mesh. Skin doesn't dissapear by getting squeezed. Unfortunately I never found a way to preserve volume. Soft bodies don't provide this feature.
BTW: Forget about realtime!
Postby PRAKHAR » Tue May 09, 2017 2:00 pm
Oh c'mon friend if you can have weight paint features & can be applied to your character through soft body, so of course computer will recognise each vertices of mesh to be deformed & how much it's to be
I have seen examples of breast physics that's to lengthy man, soft body on whole is better but ya it'll take lot of time for weight painting
PRAKHAR
Return to Off topic
