I'm trying to set up a scene where I can flip between cycles and blender render at will. To this end I'm setting up blender render nodes as well as cycles nodes in each material in the scene. For example for the eyes:
The upper set of nodes is for cycles, the lower is for blender render.
This greys out the transparency panel on the material:
I can't find any combination of settings that makes eyes render properly, when using nodes. If I disable nodes and just add the texture as normal, enable z-transparency in the material panel and set transparency alpha to 0 there, then everything works fine.
Anyone know if it's even possible to get a functional mapping of a texture alpha channel when using blender render nodes?
With the exception of materials that need a texture with an alpha channel, the strategy works surprisingly well.
