Pixar repeating textures
Postby joepal » Tue Feb 28, 2017 12:24 pm
Pixar have released 130 repeating textures used in films. They seem to include normal maps and bump maps. There are some cloth fabrics in there which look useful:
https://community.renderman.pixar.com/a ... hirty.html
Re: Pixar repeating textures
Postby joepal » Tue Feb 28, 2017 1:19 pm
A few test where texture scale is set to 15. Here we can also see why it would be useful to have a homogenous mesh density in uv unwrapping when working with repeating textures (breast area and skirt area obviously have very different mesh densities for the female formal asset).
cotton
looc
ovalcot
diam
burlap
Postby joepal » Tue Feb 28, 2017 1:31 pm
The "dimd" texture (found in the "paper" category) actually looked kind of cool on a dress...
dimd
pinkflwr
poitseta
Postby CallHarvey3d » Tue Feb 28, 2017 2:15 pm
Nice! always on the hunt for free seamless textures! wish they were at least 1024x1024 but im sure ill find uses for most of these
CallHarvey3d
Postby wolgade » Wed Mar 01, 2017 5:33 pm
Cool. I will have to try these textures.
joepal wrote:Here we can also see why it would be useful to have a homogenous mesh density in uv unwrapping when working with repeating textures (breast area and skirt area obviously have very different mesh densities for the female formal asset).
This might be fixable. I just played around with a node setup to generate homogenous uv-coordinates from object coordinates.
The main idea came from my old friend Pythagoras. u=sqrt (x²+y²), v=z. Problem: Your texture gets mirrorred on the x- and y-axis. To avoid this you have to give your 3D coordinates an offset. You'll have to play around with the values. The 2D uv-coordinates get scaled afterwards.
This is not perfect. You'll always have a region on your object that looks terrible, but it might be good enough to bake your uv islands seperately using different offsets. This is what my panties from the user repo look like with a uv grid and the above node setup.
Postby joepal » Wed Mar 01, 2017 5:50 pm
That looks very useful.
Maybe we should have a section in the docs about clothes texturing, where stuff such as this and the mindfront/punkduck tutorials could end up.
Postby wolgade » Wed Mar 29, 2017 2:43 pm
Return to Off topic
