MakeHuman and Google Cloud Services
Postby RobBaer » Wed Jan 04, 2017 4:10 pm
I was looking into google cloud services, and thought it might be interesting to see what happened with MakeHuman in that virtual environment. I installed a Ubuntu 14.04 virtual machine and ran the following commands to install makehuman:
sudo add-apt-repository ppa:makehuman-official/makehuman-11x
sudo apt-get update
sudo apt-get install makehuman
MakeHuman is installed into the directory /usr/bin Running MakeHuman resulted in the following console output:
rbaer@ubuntu-1404:/usr/bin$ makehuman
MakeHuman Copyright (C) 2001-2016 http://www.makehuman.org
This program comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to redistribute it
under certain conditions. For details use the option --license
data/VERSION file detected using value from version file: 2065:958a5d93e1d0
Initialized logging
VERSION: 1.1.0
HG REVISION: r2065 (958a5d93e1d0) [data/VERSION static revision data]
SHORT VERSION: v1.1.0
BASEMESH VERSION: hm08
IS BUILT (FROZEN): No
IS RELEASE VERSION: Yes
WORKING DIRECTORY: /usr/share/makehuman
HOME LOCATION: /home/rbaer
PYTHON PATH: ./:./lib:./apps:./shared:./apps/gui:./core:/usr/share/makehuman:/usr/lib/python2.7:/usr/lib/python2.7/
plat-x86_64-linux-gnu:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/loca
l/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages
DLL PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games
SYS.VERSION: 2.7.6 (default, Oct 26 2016, 20:30:19)  [GCC 4.8.4]
SYS.PLATFORM: linux2
SYS.EXECUTABLE: /usr/bin/python
PLATFORM.MACHINE: x86_64
PLATFORM.PROCESSOR: x86_64
PLATFORM.UNAME.RELEASE: 4.4.0-53-generic
PLATFORM.LINUX_DISTRIBUTION: Ubuntu 14.04 trusty
NUMPY.VERSION: 1.8.2
No OpenGL_accelerate module loaded: No module named OpenGL_accelerate
Unable to load registered array format handler numeric
Unable to load registered array format handler vbo
Unable to load registered array format handler vbooffset
makehuman.py: cannot connect to X server
So, it seems that MakeHuman installs but does not run. Maybe this simply means Google cloud services can't support pyQT, but it was an interesting venture. Not quite sure how X server fits in and whether I needed to start something I didn't start??
Anyway, great fun on the cloud. Just thought I'd report back.
:mrgreen:
Re: MakeHuman and Google Cloud Services
Postby joepal » Wed Jan 04, 2017 5:16 pm
Nah, the problem here is that you haven't got any X output defined:
If you run from a linux box you can do:
ssh -X <your account @ the google server>
This will forward the X output to your local machine.
On windows, you would need an X client, for example mobaxterm.
Return to Off topic
