Help exporting from MH and importing to MD
Postby sforclark » Mon Sep 26, 2016 7:25 am
I know that this isn't strictly a MakeHuman question and I am not sure where to really post this question but recently I created a model in MakeHuman 1.1.0 and I am trying to make clothing for her using Marvelous Designer 5.5. I have exporting from MakeHuman as an .obj file i selected "feet on ground" and I selected the units as cm. When I import that .obj file using Marvelous Designer I selected "use as avatar" and the units as cm as well. After it is done there is nothing there, my model is inviciable, the default clothes are floating. I tried using blender as a bridge but I got the same results. Could someone help me or point me in the right direction, this is for a school project and I am very new?
sforclark
Re: Help exporting from MH and importing to MD
Postby loki1950 » Mon Sep 26, 2016 6:32 pm
Try using the collada format on export instead of .obj the file extension will be .dae IIRC MD will import them correctly there a few MD users on the forum that will most likely chime in ;)
Postby brkurt » Mon Sep 26, 2016 8:31 pm
loki1950 wrote:Try using the collada format on export instead of .obj the file extension will be .dae IIRC MD will import them correctly there a few MD users on the forum that will most likely chime in ;)
I've used MD extensively, back in version 4 (it is finalizing version 6 right now).
the format is open collada; the best way to get there is through Blender, so you can check your work.
Feel free to use some of my models, made in MH 1.1.0:
http://www.geekopolis.ca/marvelous_designer/ginaCarano20140821.ZPrj
or
http://www.geekopolis.ca/marvelous_designer/ginaCarano1_MD4.ZPrj
The default rig passes from MH to Blender to MD very well indeed. This is important for video creation within MD.
Postby sforclark » Mon Sep 26, 2016 8:59 pm
Thank you for your replies. Just to clarify because I am currently at work right now, so import from Makehuman to blender and export from blender as a collada and import that into marvelous designer right?
sforclark
Postby brkurt » Tue Sep 27, 2016 2:11 am
sforclark wrote:Thank you for your replies. Just to clarify because I am currently at work right now, so import from Makehuman to blender and export from blender as a collada and import that into marvelous designer right?
Yes, that's how its done. I've left you two projects from MD 4 so you can get the scale right the first time. Otherwise, it's a bit frustrating not to see the rig in MD.
Also, the controls (bounding volumes?, it's been a while) have to be scaled so that you work with the avatar, rig and clothes all at once. 8-)
Be forewarned! Unless there has been a major re-design of the computed mesh since version 5, there will be triangles and quads in the final garment. MH 1.1.0 to Blender 7.x to MD 6 is most likely a one-way trip. :o
Return to Off topic
