Well, some of those heads "could" be considered female, but could also be considered male. The bulging lips could belong to an african female. I found no way to get a caucasian-looking female nose, either. Trying to make the nose thinner, you ended up having a pointy nose that looks like some monstruosity from a horror movie, just like I did, I can see.
For a soft female face first of all you need the cheeks and chin to integrate into a sort of single ovoid shape. Currently there seems to be no way to get rid of the "prominent cheek-bones and sucked in cheeks below them" -paradigm.
Secondly, you need that same, integrated ovoid shape to continue around the rest of the head. Soft forhead lines. Right now there's no way to get a soft forehead.
The eyes need to be less recessed, relative to the eyebrows; but I couldn't find a way to move the eyes forward or the eyebrows back; you're stuck with the neanderthal female look.
targets you asked are alredy done. ... there are a lot of new head targets already done
Good news!; can't wait.
EDIT:
Come to think of it, I'm beginning to doubt the whole androgyn paradigm can ever work, though.
That's NEVER going to work; and I'll tell you why: Scientifically speaking, the male gender is a modification of the female gender; NOT the other
way around. The male and female genders are not modifications of some "androgyn middle", either. Wrong
mental model, guys.
The "ground state" or "default" of human physionomy is the female physionomy:
When a woman is pregnant with a female baby, there are no special, hormonal duties for her body to perform. Female baby pregnancies
are "much less work" for the mothers to be.
When a woman is pregnant with a male baby, on the other hand, her body has to produce copious amounts of testosterone and inject them
into the placenta. To whatever extent, for nutritional, or whatever other reasons, she's unable to produce testosterone, at some point in
time during the fetus' development, to that extent, whatever organs were developing at that time, will develop in a female way. Which
is why some babies are born with wrong genitalia vis-a-vis chromosomes. (In fact, male gayness results when the levels of testosterone in
the placenta are insufficient at the time the brain tissues responsible for "opposite sex" recognition are developing; --a well known fact in
science circles, but which is never written about in public media for political reasons.) (AND, before you ask, real female gayness is rare,
and in the vast majority of cases it occurs to females with male twins; --their mother's body having injected male hormones into the
placenta trying to suit the development of the male fetus, causing parts of the body or brain of the female fetus developing in a male way.)
But yeah, I think you guys had better consider starting again, from a female model.
Sorry to break it to you so hard, but I don't think you'll ever be able to make a female out of a male OR "androgyn" model.
Never. It's hopeless.
For comparison, imagine this was some MT (Make Terrain) project, and there was a slider to go from flat plains to high mountains.
Whould you start from a "medium mountains" model and then have a control to decrease the height of each individual mountain separately
for when people want a flat plain? That would be absurd, wouldn't it?
But that is exactly what you're doing. You'll never get a smooth, ovoid chin as you need for a female face by tweaking the polygonal-looking
chin of a male --or even androgyn-- model. Never!
You need to start from a "flat plain", and have features that modify it to make something else; --i.e.: your basic model should be the softest
female body, head and face, humanity ever produced; and then male features would be modifiers of that; the way our biology actually works.
EDIT 2:
For a mathematical visualization of a true female-male physionomy paradigm, you need to put the female at the zero end of the scale, and
then consider "degree of maleness" as a logarithmic control. From a "soft male" to a hairy viking you probably go through like an order of
magnitude or two in 'amount of maleness'. Thus, there is no such thing as an "androgyn". If you were to average a female with a viking male
you'd get a middle that is much more male than most males, in other words.
Which in other words means that "androgyn" is something that doesn't exist because the concept itself is ill-conceived.
It's like when someone said to me that the "spiritual center" of the solar system was not where the sun is, but the center of the ellipses of the
planetary orbits. I had to break it to her that for each planet, the orbital ellipse has a different center from that of any other planet's orbital
ellipse.
Similarly here, there's no such thing as a "center" between male and female, because males are like a family of ellipses, where femaleness is
like a circle.
More to the point, female forms have less "harmonics". Their "curves" approximate more transcendental functions. The sine wave is named
after some of those curves.
Maleness adds harmonics, varying in intensity and frequency cutoff by like orders of magnitude.
I'm really sorry to be the messenger of bad news, but I have a duty to tell you: you're going down a blind alley. Better turn around now, before
you invest too much more time and effort on the wrong paradigm.
EDIT 3:
Or if you like a sound analogy: The original Moog sythesizers made their limited repertoire of sounds by starting from 3 waveforms: Pure
sinewave, square wave, and saw-tooth, mixing them and filtering them. In sound synthesis, that's called "synthesis by subtraction", and
it was terribly limited.
Synthsis by addition was the best, but very "expensive" to produce.
FM synthesis was a sort of clever trick to produce something like synthesis by addition but more cheaply and with less controlling parms.
What you're doing right now is like "synthesis by subtraction": To get to female forms from "androgyn" is like trying to subtract harmonics.
It's NEVER going to work.
EDIT 4:
I'm mostly talking about faces, in case my writing wasn't clear.
The body approach of MH seems to be working pretty well. For faces, however, there absolutely NEEDS to be a female-male slider.
Trying to get to a female face piece-meal by tweaking targets from an "androgyn" face is what I'm saying will never work.
