Skins Library Errors
Postby kyoos » Sun Mar 03, 2024 1:18 pm
"I just installed an add-on and created a human mesh, then loaded the skin and got this error message. Does anyone know what the problem might be? I need help."
Python: Traceback (most recent call last):
File "C:\Users\tjrry\AppData\Roaming\Blender Foundation\Blender\4.0\scripts\addons\mpfb\ui\assetlibrary\operators\loadlibraryskin.py", line 38, in execute HumanService.set_character_skin(self.filepath, basemesh, bodyproxy-bodyproxy, skin_type skin_type, material_instances-material_instances)
File "C: \Users \tirry \AppData\Roaming \Blender Foundation\Blender\4.0\scripts\addons \mpfb\services\humanservice.py", line 591, in set_character_skin enhanced_material.apply_node_tree(blender_material)
File "C: Users tirry \AppData Roaming Blender Foundation\Blender\4.0|scripts \addonsImpfb\entities|material\enhancedskinmaterial.py", line 99, in apply_node_tree
NodeService.apply_node_tree_from_dict(blender_material.node_tree, node_tree_dict, True)
File "C: Users it|rry\AppData\Roaming Blender Foundation\Blender\4.0|scripts|addons\mpfb|services\nodeservice.py", line 571, in apply_node_tree_from_dict NodeService._ensure_group_interfaces_exist(dict_with_node_tree)
File "C: \Users\tjrry\AppData\Roaming \Blender Foundation\Blender\4.0|scripts\addons\mpfb\services\nodeservice.py", line 540, in _ensure_group_ interfaces_exist if not input_name in node_tree.inputs:
AttributeError: 'ShaderNodeTree' object has no attribute 'inputs'
kyoos
Re: Skins Labrary errors
Postby ritacarter » Fri Nov 22, 2024 1:36 am
I also get the same error message. Did you find any solution?
ritacarter
Postby joepal » Fri Nov 22, 2024 2:06 pm
The minimum required blender version for MPFB is 4.2. From the stack trace it looks as if you are running blender 4.0.
