Re: Creating a clothes library: some technical aspects
Postby robertltux » Fri Feb 10, 2012 5:10 pm
mind sharing your shoes??
robertltux
Postby duststorm » Fri Feb 10, 2012 8:25 pm
Here's all the source files.
I made clothes packages for MH, but they're not finished yet.
As usual, blend source is attached and here is the source gimp file: http://duststorm.ulyssis.be/mh/shoes_te ... ources.zip
mh_shoes_blend.zip
Source blender file
(1.79 MiB) Downloaded 1130 times
Red texture variation
mh_shoes_sport_white.zip
White sports shoes MH package (only high)
(489.08 KiB) Downloaded 774 times
mh_shoes_sport_blue.zip
Blue sports shoe MH package (only high)
(483.84 KiB) Downloaded 884 times
mh_shoes_brown.zip
Brown shoes MH format (low and high poly version)
(729.27 KiB) Downloaded 789 times
Postby robertltux » Fri Feb 10, 2012 8:38 pm
thanks do you mind if i use them to make some ballet slippers??
robertltux
Postby duststorm » Fri Feb 10, 2012 11:09 pm
A proper license needs to be found for them I think. At the moment, as they are part of the MH project, they share the same license as everything else that comes out of MH.
Postby Lemon » Sat Feb 11, 2012 7:29 am
duststorm, that's just great! You've started that important library-enriching process, which was highly expected by all MH users, I believe :)
Lemon
Postby ThomasL » Sat Feb 11, 2012 8:00 am
Hm. Actually, you have released your clothes under GPL3. At least that what it says at the top of the mhclo files.
The makeclothes script looks for a file called proxy_header.txt in your home makehuman directory, and copies its content at the top of the exported mhclo file, with lines prepended with a #. If this file is not found, some default lines are printed instead.
ThomasL
Postby duststorm » Sat Feb 11, 2012 12:38 pm
Aha. Apparently I haven't paid a lot attention to that yet.
Anyway, that seems like a good default.
There's still a lot to fix up before these can be called final. I even don't have masks yet..
Postby ThomasL » Sun Feb 12, 2012 9:50 am
duststorm wrote:Aha. Apparently I haven't paid a lot attention to that yet. Anyway, that seems like a good default.
It was not the intention to trick unaware clothes-makers to use GPL license. I just put the info there a long time ago when I was the only one using the script. Setting the author/license info has been moved to the bottom of the panel, where it is more visible. Like the other properties, they are stored permanently when you press the Save settings button, so you don't have to retype it.
ThomasL
Postby duststorm » Sun Feb 12, 2012 1:55 pm
And I've created a dfferent type of shoe.
Classic shoes for MH
The low poly version is 182 quads per shoe.
The high poly version 728 quads per shoe.
Topo, low poly version
Topo High poly version
I reused the topo of the sports shoes as base, but modified it. I think I added 1 or 2 loops, the polycount is a little higher than the sports shoes.
Postby duststorm » Sun Feb 12, 2012 2:45 pm
Thomas, I have some more questions to fire at you.
Trying to assign the original uv mapping of the basemesh to the shoes gave me some pain.
Of course, mapping the shoes to the feet area is probably (together with the hands) one of the most troublesome cases.
Difficult to map uv seams
As the picture shows it's quite hard to fit the seams to the shoes decently. I also feel that adding extra edges to the shoes would ruin the topology of the shoe mesh, so I'm wondering if there could be a better approach.
My thoughts: since I'm not using the basemesh uv mapping for texturing, it probably doesn't have to be perfect. It will just have to match the areas of the body it covers as best as possible.
So I was wondering: what if the clothes script could have an option to just copy over the uv coordinates using the mapping of clothes to human mesh vertices it made? So each vertex of the shoes would receive the middle uv coordinate of the basemesh triangle it is matched to.
This would at least give a good starting point which could be edited manually.
What do you think?
