How to make PovRay or Aqsis work with nightly builds?
Re: How to make PovRay or Aqsis work with nightly builds?
Postby Lemon » Thu Feb 09, 2012 6:46 am
And in what file Aqsis path shlould be set?
This time MH can't find Aqsis.
I'm a bit surprised it didn't look for aqsis.exe in Program Files/Aqsis/bin
Lemon
Postby mflerackers » Thu Feb 09, 2012 6:51 am
Makehuman does not guess where aqsis is, it uses the path variable. Is the aqsis path in your path? Type path in a command prompt to see the path variable.
MakeHuman project Developer
mflerackers
Postby Lemon » Thu Feb 09, 2012 6:56 am
mflerackers wrote:Makehuman does not guess where aqsis is, it uses the path variable.
I see. So how can I change the path variable value using the command prompt? Or should it be set in some file?
Lemon
Postby mflerackers » Thu Feb 09, 2012 7:06 am
If you change it in the command prompt, it is only changed for that session, so
SET PATH=%PATH%;"C:\Program Files\Aqsis\bin"
makehuman
would work
A more permanent change is through the windows settings: http://geekswithblogs.net/renso/archive ... ows-7.aspx
mflerackers
Postby Lemon » Thu Feb 09, 2012 7:10 am
Thank you very much, mflerackers ! :) That's really helpful.
Lemon
Postby Lemon » Thu Feb 09, 2012 7:45 am
Now Aqsis works. But POV-Ray still gives me error messages
Lemon
Postby mflerackers » Thu Feb 09, 2012 7:51 am
Comment line 130 in makehuman\apps\mh2\mh2povray.py
print mh2povray_ini.povray_path + cmdLineOpt
like this
#print mh2povray_ini.povray_path + cmdLineOpt
mflerackers
Postby Lemon » Sat Feb 11, 2012 7:04 am
Now everything works fine! Many thanks again!
Lemon
Users browsing this forum: Yahoo [Bot] and 1 guest
