Working with FaceGen + MH, something is missing.
Postby TioMegamanX » Sun Oct 02, 2022 5:22 am
The program is supposed to come with some model sets including Make Human but among the ones I got the MH doesn't seem to be included, does it come only with 3.6 or how does it work?
TioMegamanX
Re: Working with FaceGen + MH, something is missing.
Postby tomcat » Sun Oct 02, 2022 11:04 am
TioMegamanX wrote:The program is supposed to come with some model sets including Make Human…
Nope.
…or how does it work?
The program can work with MH, but it is quite a pain to organize:
MakeHuman
  • Select the MakeHuman model set. The 'a8_v74' mesh will appear. Export to OBJ
  • Use the MakeTarget Blender plugin to create a .target file (the MakeTarget standalone program uses an older incompatible mesh)
  • Overlay the original MakeHuman mouth and teeth textures on the exported texture image, if desired.
Postby TioMegamanX » Mon Oct 03, 2022 1:34 am
When I read "select the MakeHuman model set" I thought it would mean inside the program.
So I have to make my own model set using Customizer from the ground up?
TioMegamanX
Postby tomcat » Mon Oct 03, 2022 10:13 am
TioMegamanX wrote:So I have to make my own model set using Customizer from the ground up?
Apparently so… and use the file obtained from FaceGen as a target for morphing… if I understand the instructions correctly. I haven't worked with FaceGen.
What are the advantages of FaceGen versus creating faces in MH itself?
Postby TioMegamanX » Tue Oct 04, 2022 2:39 am
tomcat wrote:Apparently so… and use the file obtained from FaceGen as a target for morphing… if I understand the instructions correctly. I haven't worked with FaceGen.
For me at least it would be one less step by having FG making the morph target for a custom face instead of me trying to do it by hand using pictures every time, MH sliders are just too limiting in a few places.
TioMegamanX
