Export to povray, grid for subsurface.
PostPosted: Mon Nov 07, 2011 8:03 am
by jkroby
Hi all,
an information, how can you export to povray a model with a finer grid?
I need it because when I enable the subsurface of povray, test development, the model seems covered with a cobweb I suppose for the angle between triangles of the mesh.
I tried to smooth the model and then import it but apart from a translation or scaling was the same, about 15000 elements.
Thanks Roberto.
Re: Export to povray, grid for subsurface.
PostPosted: Mon Nov 07, 2011 1:13 pm
by jkroby
I enclose a picture to better explain the problem,
you see a piece in the background of the head covered by a ball to right,
the sphere has the same type of surface and color of the head as the ball is uniform but the head looks as a web.
The hair is a pseudo esperimeto povray with transparencies and textures.
immagine: http://www.p3r.info/povray/sub4.png
PostPosted: Mon Nov 21, 2011 10:12 am
by Manuel
You should export the mesh with the "subdivide" option enabled.
Best,
