Vertex index of topology
Postby ZBobiu » Tue Apr 20, 2021 7:38 am
If possible, where can I know the vertex index of each topology?
ZBobiu
Re: Vertex index of topology
Postby JESTERRRRRR » Wed May 05, 2021 9:59 pm
Attachment image is so small, I can't make it any bigger?
JESTERRRRRR
Postby jwc » Thu May 06, 2021 6:21 am
It's not clear what you are requesting, so I will post one possible answer
As seen in the attached image, mesh vertex indices can be viewed in Blender 2.9 by selecting the Developer Indices check box under Viewport Overlays.
This check box is only displayed when "Developer Extras" is enabled under Blender -> Edit -> Preferences -> Interface
This answer is obviously only helpful if you were interested in looking at a small region of the mesh.
Mesh Vertex Index display
jwc
Postby ZBobiu » Tue May 11, 2021 10:58 am
jwc wrote:It's not clear what you are requesting, so I will post one possible answer
I will try it out, your answer is of great help to me, thank you!
ZBobiu
Postby makehuman987 » Mon Aug 30, 2021 10:03 am
hi,
I change the "Developer Extras" in blender, but when I open the Viewport Overlays, there is no mesh edit mode, just as the attachment shows. Could you tell me what the problem is? Thanks.
makehuman987
Postby jwc » Tue Aug 31, 2021 5:59 am
Did you scroll down in the Viewport Overlays window?
The mesh edit mode and developer indices section are below Motion Tracking, which is the lowest item shown in your image.
jwc
