openSUSE packages available for testing
Postby pepo » Thu Sep 17, 2020 11:53 pm
Hello, if you are using the openSUSE Linux distribution (either version 15.1, 15.2, or Tumbleweed), you might be interested to try the MakeHuman packages I created at my home:cfeck repository.
https://software.opensuse.org/download/ ... me%3Acfeck
Clicking the .ymp buttons will install the Python dependencies and all four required packages:
* makehuman
* makehuman-assets
* makehuman-base-female
* makehuman-base-male
You can also manually add the repository; instructions are on the same page.
The MakeHuman version is currently 1.2.0-beta2.
To start the application, run /usr/share/makehuman/makehuman (it is suggested to add this to the start menu).
pepo
Re: openSUSE packages available for testing
Postby joepal » Fri Sep 18, 2020 9:28 am
Thank you, that is very helpful.
Would it be OK if I contact you as and when we start preparing for the final MakeHuman 1.2.0 stable release, and ask you if you can rebuild SUSE release packages then?
Postby pepo » Mon Sep 21, 2020 9:24 pm
Sure, I plan to update the package irregularily from master branch anyway, but please don't delay release if I don't react in time. Does it make sense to package the community plugins yet?
pepo
Postby joepal » Tue Sep 22, 2020 2:16 pm
It definitely makes sense to package MHAPI, Socket, asset downloader and mass produce.
The blender side plugins are less obvious. It depends on if suse has a dependable packaging of blender. Ubuntu does not, so we have actively not packaged any of the blender side plugins as deb.
