Busted clothes in MC2
Postby SaltyCowdawg » Sat Feb 22, 2020 10:23 pm
I just created a very simple piece of clothing (actually it is a WIP) consisting of a skirt split up the sides. When a dressed an avatar in it I see this:
split up the sides and torn in the front
so what could I be doing wrong?
Re: Busted clothes in MC2
Postby MTKnife » Sun Feb 23, 2020 4:09 am
The short answer is, MH doesn't handle clothes that don't cling to the body very gracefully; they're particularly vulnerable to distortions when placed on models different from the default they were designed with in Blender.
You want to have a look here:
http://www.makehumancommunity.org/wiki/ ... on:Clothes
Specifically, scroll down to "What if automatic vertex groups don't work?" While I was the one who wrote that section, I've since found that sometimes just doing things the default way works better--and I can't predict when that will happen. In your case, that's obviously not going to be true, but I would try it with and without step #3--whether that one improves or harms things is very hit-or-miss.
MTKnife
Postby Elvaerwyn » Sun Feb 23, 2020 4:24 am
Allo Salty, did you use the skirt helper to port this? If not I would recommend giving that a try-have had great success with this with new convert clothes.
Postby SaltyCowdawg » Sun Feb 23, 2020 2:14 pm
I did. I actually used the skirt helper as a starting point. Beginning to think that might have been the issue.
Slugging away at this.
Postby MTKnife » Sun Feb 23, 2020 4:50 pm
The skirt helper usually works pretty well--I think it's the most useful of all the helpers.
MTKnife
