FBX Export Faces Under Clothes?
Postby Atom » Fri Jun 01, 2018 3:07 pm
Is there a way to FBX export hidden faces under the clothes?
Atom
Re: FBX Export Faces Under Clothes?
Postby RobBaer » Fri Jun 01, 2018 8:18 pm
Atom wrote:Is there a way to FBX export hidden faces under the clothes?
Yes. On the geometries tab as you are placing the clothes, uncheck the "hide faces under clothes" radio button under options on the left panel. This might (depending on your clothes and model) make the model "poke through" the clothes.
You will then have to slightly adjust the clothes to your specific model, once imported into Houdini. Of course, the clothes will only need to be "custom fit once", but this is the price for fitting clothes to widely varying body types AND keeping the underlying skin intact.
Edit: oops! By mistake, I edited your original post rather than quoting it. But I left the important part of your question. Sorry :oops:
Rob
Postby Atom » Fri Jun 01, 2018 9:01 pm
Thanks Rob, I'll look for that setting the next time I am exporting. I noticed one bit of clothing, the MAGA hat did not remove faces underneath. Is the setting linked to each piece of clothing? Can the author of clothing set that flag on the asset?
Atom
Postby Aranuvir » Fri Jun 01, 2018 10:44 pm
The asset creator must define a vertex group called 'Delete' on the human mesh in order to work.
