I'm running the python3 branch because I have python 3, not 2, installed. (I had python 2 installed at one point, but uninstalled it to stop them from interfering. But with managing environments on pycharm, maybe I could install it again if I had to.)
This is what I get when I run the script (in a pycharm "scratch" file):
- Code: Select all
PyQt5 found
Numpy found
OpenGL found
Python version : 3.5.2 (v3.5.2:4def2a2901a5, Jun 25 2016, 22:18:55) [MSC v.1900 64 bit (AMD64)]
Process finished with exit code 0
edit: I see joepal's post now. I already downloaded the one on the main downloads page. I waited for it to unzip so that I could check in one of the plugin files to see what version it was, to see if it was also python 3 and I wouldn't have to also download the one in joepal's link. It said python 2.7 at the top so I went to the nightly build, but it also says python 2.7 at the top of the script. I'm going to assume they're the same so that I don't have to wait ages again for another one to unzip, and run the one I downloaded from the main page.
(both zip files have lots of package pyd files, which is different. but they also both have python27.dll. eh...)
waiting an eternity for the startup thing to appear, while its annoyingly warm and humid in my room because it's too nice outside to run the a/c or something, gotta make up for it by being uncomfortable inside! whine whine whine, wait wait wait... so much waiting...
ok it finally loaded and this exe which I assume is py3, is not broken. I hope I dont have to wait another epoch for the other one to unzip and load again...
There is one warning, which says:
- Code: Select all
C:\Users\[name]\DOWNLO~1\MAKEHU~1.1-W\OpenGL\GL\VERSION\GL_2_0.py:374: FutureWarning: comparison to `None` will result in an elementwise object comparison in the future.
Also this notice, which printed four times, which I saw when running from source but probably don't remember seeing it in the python 2.7 version:
- Code: Select all
Setting rendering_width is already declared. Adding it again has no effect.
edit2: a few minutes after exiting pycharm, after hitting the dialog boxes that asked me if i wanted to terminate the makehuman process (despite not having any makehuman windows open), a py3 community blank screen MH loading box appeared. The 3d viewer windows is gray instead of white, so I hoped that meant that it was the exe, so then my situation would apparently make sense, but then based on one of the error messages, it seems to be the refactor branch (but running from appdata instead of pycharm).
