Using MakeHuman models in VR environments
Postby blindsaypatten » Sat Nov 04, 2017 4:59 pm
Yesterday I incorporated a MakeHuman model in a Samsung Gear VR environment using Unity. I'm just wondering if anyone else is working with MakeHuman models in VR? If so, for which VR hardware and using what software?
Re: Using MakeHuman models in VR environments
Postby brkurt » Sat Nov 04, 2017 7:50 pm
Postby joepal » Mon Nov 06, 2017 12:29 pm
MH models work more or less out of the box with Unity, via FBX export. See http://www.makehumancommunity.org/wiki/ ... them_there. Unity has a one checkbox solution for targeting VR headsets ("virtual reality supported", on or off), see https://unity3d.com/learn/tutorials/top ... r-overview.
Personally, I've ran Unity projects on oculus rift so far. This is a pretty smooth experience.
Postby jorgeo » Thu Dec 21, 2017 5:35 pm
I'm also using Makehuman for Unity, target platforms HTC Vive and Oculus right now.
https://youtu.be/V7_Qi-rMjRM
jorgeo
Postby jujube » Sat Apr 21, 2018 7:45 pm
I recently got a gear vr, and I love it but I'm annoyed by the fact that there's no generic 3d model viewer on it. So now I have to 1. learn unity 2. learn how to get the unity games onto my phone.. so much learning /whine
Postby CallHarvey3d » Tue Jun 12, 2018 1:49 pm
there were some cheap/free apps that allowed import of textured objs that i had used a few years ago i havnt looked in awhile but i imagine there's more now with some gesture support.
CallHarvey3d
Postby ecke101 » Thu May 09, 2019 7:03 pm
Is there any chance Makehuman could support VR in the future? It shouldn't be so hard to implement.
I would try to modify the code if I could but I think it's too advanced for me.
There are OpenVR bindings for Python and a simple example how to get headset position and rotation.
https://github.com/cmbruns/pyopenvr
Would be amazing to be able to preview characters in VR fast to get a better feel for how they really look.
ecke101
Postby joepal » Fri May 10, 2019 10:59 am
Without having looked, I'm guessing that our stone age OpenGL core would put in a few hurdles. It would probably have to be modernized first.
Postby ecke101 » Thu Aug 08, 2019 9:33 pm
I'm a total Python newbie but somehow managed to hack together a "working" VR viewer plugin for MakeHuman. There are some OpenGL errors in the log and it crashes if you close the window.. so if there is someone out there with an OpenVR-compatible headset who can help me that would be nice.
(2019-08-10) edit: Updated the code. Now it draws the body mesh colored by the normals.
You need to "pip install openvr" or install pyopenvr manually and have SteamVR installed.
7_VR.py (in the "/plugins"-folder):
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
import gui3d
import mh
import gui
import log
import numpy
from core import G
from openvr.glframework.qt5_app import MyGlWidget
from openvr.gl_renderer import OpenVrGlRenderer
from PyQt5.QtWidgets import QMainWindow
from PyQt5.QtOpenGL import QGLFormat
from textwrap import dedent
from OpenGL.GL import *  # @UnusedWildImport # this comment squelches an IDE warning
from OpenGL.GL.shaders import compileShader, compileProgram
from openvr.glframework import shader_string
class MHActor(object):
    def __init__(self):
        self.shader = 0
        self.vao = None
        self.humanchanged = False
    def updateVertices(self):
        self.vertices = []
        self.faces = []
        self.normals = []
        yOffset = -1 * gui3d.app.selectedHuman.getJointPosition('ground')[1]
        for obj in sorted(G.world, key = (lambda obj: obj.priority)):
            # log.message(obj.isTextured)
            # log.message(obj.solid)
            # log.message(len(obj.verts))
            # log.message(len(obj.primitives))
            # log.message(obj.primitives)
            # log.message('---')
            if obj.vertsPerPrimitive == 4 and len(obj.verts)>4:
                for vert in obj.verts:
                    self.vertices.append([vert[0],vert[1]+yOffset,vert[2]])
                for n in obj.norms:
                    self.normals.append(n)
                for fv in obj.primitives:
                    self.faces.append(fv[0])
                    self.faces.append(fv[1])
                    self.faces.append(fv[2])
                    self.faces.append(fv[3])
        self.faces = numpy.array(self.faces, dtype=numpy.uint32)
        self.vertices = numpy.array(self.vertices, dtype=numpy.float32)
        self.vertices = self.vertices * 0.1
        self.normals = numpy.array(self.normals, dtype=numpy.float32)
    def init_gl(self):
        vertex_shader = compileShader(
            shader_string("""
            layout(location = 0) uniform mat4 Projection = mat4(1);
            layout(location = 4) uniform mat4 ModelView = mat4(1);
            layout(location = 8) uniform float Size = 0.3;
            in vec4 position;
            in vec3 normal;
            out vec3 fnormal;
            void main() {
              gl_Position = Projection * ModelView * Size * position;
              fnormal = normal;
            GL_VERTEX_SHADER)
        fragment_shader = compileShader(
            shader_string("""
            out vec4 FragColor;
            in vec3 fnormal;
            void main() {
              FragColor = vec4(normalize(fnormal), 1.0);
            GL_FRAGMENT_SHADER)
        self.shader = compileProgram(vertex_shader, fragment_shader)
        glEnable(GL_DEPTH_TEST)
        self.updateVertices()
        self.vao = glGenVertexArrays(1)
        glBindVertexArray(self.vao)
        self.vertex_buffer = glGenBuffers(1)
        self.normal_buffer = glGenBuffers(1)
        self.element_buffer = glGenBuffers(1)
        glBindBuffer(GL_ARRAY_BUFFER, self.vertex_buffer)
        position = glGetAttribLocation(self.shader, 'position')
        glVertexAttribPointer(position, 3, GL_FLOAT, False, 0, ctypes.c_void_p(0))
        glEnableVertexAttribArray(position)
        glBufferData(GL_ARRAY_BUFFER, self.vertices.size*4, self.vertices, GL_STATIC_DRAW)
        glBindBuffer(GL_ARRAY_BUFFER, self.normal_buffer)
        normal = glGetAttribLocation(self.shader, 'normal')
        glVertexAttribPointer(normal, 3, GL_FLOAT, False, 0, ctypes.c_void_p(0))
        glEnableVertexAttribArray(normal)
        glBufferData(GL_ARRAY_BUFFER, self.normals.nbytes, self.normals, GL_STATIC_DRAW)
        glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, self.element_buffer)
        glBufferData(GL_ELEMENT_ARRAY_BUFFER, self.faces.nbytes, self.faces, GL_STATIC_DRAW)
        # glBufferData(GL_ARRAY_BUFFER, self.vertices.size*4, self.vertices, GL_STATIC_DRAW)
        # glBindVertexArray( 0 )
        # glBindBuffer(GL_ARRAY_BUFFER, 0)
        # glBindBuffer(GL_ELEMENT_ARRAY_BUFFER, 0)
    def display_gl(self, modelview, projection):
        glUseProgram(self.shader)
        glUniformMatrix4fv(0, 1, False, projection)
        glUniformMatrix4fv(4, 1, False, modelview)
        if (self.humanchanged):
            # log.message("human changed")
        glDrawElements(GL_TRIANGLES, len(self.faces), GL_UNSIGNED_INT, None)
        # glDisableVertexAttribArray(0)
        # glDisableVertexAttribArray(1)
    def dispose_gl(self):
        glDeleteProgram(self.shader)
        self.shader = 0
        if self.vao:
            glDeleteVertexArrays(1, (self.vao,))
        self.vao = 0
class VRWindow(QMainWindow):
    def __init__(self):
        super().__init__()
        self.setWindowTitle("VR test window")
        self.resize(800,600)
        self.mhactor = MHActor()
        renderer = OpenVrGlRenderer(multisample=2)
        renderer.append(self.mhactor)
        glformat = QGLFormat()
        glformat.setVersion(4, 1)
        glformat.setProfile(QGLFormat.CoreProfile)
        glformat.setDoubleBuffer(False)
        self.glwidget = MyGlWidget(renderer, glformat, self)
        self.setCentralWidget(self.glwidget)
        self.show()
    def closeEvent(self,event):
        self.glwidget.disposeGL()
        event.ignore()
        #QMainWindow.closeEvent(self, event)
class VRTaskView(gui3d.TaskView):
    def __init__(self, category):
        gui3d.TaskView.__init__(self, category, 'VR')
        box = self.addLeftWidget(gui.GroupBox('VR'))
        self.aButton = box.addWidget(gui.Button('Open VR window'))
        self.vrwindow = 0
        @self.aButton.mhEvent
        def onClicked(event):
            self.vrwindow = VRWindow()
            self.vrwindow.show()
    def onShow(self, event):
        gui3d.app.statusPersist('VR plugin')
    def onHide(self, event):
        gui3d.app.statusPersist('')
    def onHumanChanged(self, event):
        if self.vrwindow != 0:
            self.vrwindow.mhactor.humanchanged = True
category = None
taskview = None
# This method is called when the plugin is loaded into makehuman
# The app reference is passed so that a plugin can attach a new category, task, or other GUI elements
def load(app):
    category = app.getCategory('Utilities')
    taskview = category.addTask(VRTaskView(category))
# This method is called when the plugin is unloaded from makehuman
# At the moment this is not used, but in the future it will remove the added GUI elements
def unload(app):
    pass
ecke101
