blindsaypatten wrote:Do I recall that someone has already ported the MHX2 export code to the python3 port? If so, can you tell me how to get it and install it? I took a quick look at porting it and got slogged down enough to see if someone has already done it. Thanks.
Actually, it appears that the only change in the MHX2 export code is in save_json.py on line 54 where
elif isinstance(data, (str, unicode)):
should be changed to
elif isinstance(data, str):
There is a problem that manifests in guiexport.py where if you use the file selector to specify the output file the path gets messed up:
event.path: ('C:\Users\Lindsay\Documents\makehuman\v1py3\mhx2_exports\test2.mhx2', 'MakeHuman Exchange (*.mhx2)')
but if you specify the name in the input box it works okay:
event.path: C:\Users\Lindsay\Documents\makehuman\v1py3\exports\test1.mhx2
