Can't make clothes because "Texture not Found"
Postby KingCon16 » Mon Sep 19, 2016 1:10 am
I have followed tutorials on how to make you own clothes with MakeClothes in Blender but whenever I click the "Make Clothes" button I keep getting this message saying that the operation was successful but the texture/materials were not found, how do I fix this?
KingCon16
Re: Can't make clothes because "Texture not Found"
Postby loki1950 » Mon Sep 19, 2016 3:43 am
First off are you assigning the texture completely in blender then make sure that texture is someplace that makehuman can use in the same folder as the clothes item is saved to,you can do that assigning within MH using the Materials Editor in the Utilities tab as well.Just post again if you need more specific info please and your OS info as that will help me tailor my response.
Postby SaltyCowdawg » Tue Sep 20, 2016 1:58 pm
KingCon16 wrote:I have followed tutorials on how to make you own clothes with MakeClothes in Blender but whenever I click the "Make Clothes" button I keep getting this message saying that the operation was successful but the texture/materials were not found, how do I fix this?
My user experience would tell me that perhaps you are working in Cycles and adding an Image texture and losing the image texture? Is this where you're at?
Postby loki1950 » Tue Sep 20, 2016 3:21 pm
And yeah as Salty says the addon does not work with cycles at all only with the default blender render.
Postby wolgade » Tue Sep 20, 2016 10:50 pm
I keep getting this error message very often. My solution is to make paths absolute.
Postby KingCon16 » Wed Sep 21, 2016 9:43 pm
I made the paths absolute and I got this message to pop up, its an improvement but where do I go from here?
P.S. thanks for the help so far :D
supposedly found texture
KingCon16
Postby Aranuvir » Wed Sep 21, 2016 10:17 pm
In the N-Panel there are options where you can fill in the author and license. You can ignore this, if you don't want to share your work anyway. You can edit the files afterwards by hand, too. They are mostly text files (mhmat and mhclo).
Postby Zeesy » Tue Feb 28, 2017 9:27 pm
Thanks for the great advice! I was having the same issue, which is now resolved. A note for other people - check to make sure that you haven't renamed any of your texture files.
Zeesy
Postby dingsboms » Mon Feb 28, 2022 8:28 pm
Also make sure your file name doesnt have any spaces in it like Texture Base Color.png.. Switch it to TextureBaseColor.png
dingsboms
