RobBaer wrote:So, being quite new to Ubuntu I've had some trouble understanding how to properly test different driver combinations. When you tested the two ppa were you "uninstalling" something before installing the second one? Or, can you just download and install over the top? When there are apt-get package managers involved are there other special considerations for "doing this right"?
You do not need to uninstall old drivers.PPA just adds an extra repository to /etc/apt/source.list. To achieve this run
- Code: Select all
sudo add-apt-repository ppa: launchpad_user_name/repo_name e.g: oibaf/graphics-drivers
sudo apt-get update
If an older versions of the software is already installed (e.g. graphic-drivers), just run
- Code: Select all
apt-get dist-upgrade
in case of new software (e.g. makehuman) run
- Code: Select all
apt-get install makehuman
In case of graphics drivers you need to restart at least the X-server, log out or better reboot. General hint: every ppa shows the information you need to install it.
to remove a ppa use ppa-purge (needs to be installed first!)
- Code: Select all
ppa-purge ppa:launchpad_user_name/repo_name
then apt-get uninstall --purge packagename or in case you want to downgrade (e.g. drivers) apt-get update + dist-upgrade
How would I go about rolling back to the Ubuntu 16.04 upgrade that existed when I first upgraded from 14.04, because I'm thinking MH was rendering fine until a "mesa upgrade". If you know Docs worthy of reading I'm game to check them out!
I don't now a way back. You can use a live media to test. It is also possible to install software in live mode. Get a 16.04 iso, since 16.04.1 is already an updated version from July. I have recently checked a 16.04 Kubuntu, too, with the same result (hint: I wasn't able to resolve and install all dependencies for MakeHuman on Ubuntu so I had to switch to Kubuntu, probably the problem was on my testing setup). Here is a US-server
http://mirror.pnl.gov/releases/ . Maybe you find a server, that suits better...
