joepal wrote:I'll take a look at it tonight and see if it works in Unity too.
Ok, apart from the fact that I don't know what the hell I'm doing when I'm playing around inside Unity:
joepal wrote:The purpose was to stop someone from writing a plugin with a simple forEach loop that exported the entire internal MakeHuman database structure and then be allowed to use that dump under a CC0 license.
It is unfortunate that the general wording also happen to cover MHX2.
if all the needed info is possible to save to an FBX file
wolgade wrote:It's not unfortunate, it's a desaster. It prevents anyone from modifying and enhancing the source code. This is not only true for MHX2, but for any other legitimate plugin or modification someone might write. That's exactly what Open Source doesn't want to happen.
joepal wrote:You're welcome to modify the source code in any way you want as long as you fulfill the obligation stipulated in AGPL. That's the same as in any other AGPL-licensed application.
moinator wrote:Would it be an option as middleway to put the mhx2 plugin on the makehuman website to make it official [..]?
moinator wrote:Would it be an option as middleway to put the mhx2 plugin on the makehuman website to make it official and allow people that used it in the past and even the original author of the plugin (who is in the same boat with all others regarding that) to use it with CC0? This would not require to rethink or touch the current license model and you already know that it's not made to do some foreach loop.
Oscalon wrote:Thomas, do you have any plans to expand mhx2 to be able to handle the new makehuma rig+facerig, and to be able to make IK controls for it?
Oscalon wrote:If not, do we have information or docs on how exactly the current IK rig is setup? I know we have an FK and IK rig and controls to switch them. If I can get more details, I may be able to recreate something.
